PIC18F4550 and KS0108 "eBay" 128x64 Display Proble
dksoba
Member level 2
I got a ks0108 LCD off eBay, but I think it's busted.
First of all, Vee only goes to -5V, not sure if that's enough. I think this may be causing the contrast problem, but also I'm using a 50K pot not a 20k pot.
Secondly, if you see the attached pictures, it shows that the left half of the screen is complete junk. Now, I was thinking "Hrmm...maybe one of the CS's is not working". Well, if I swap the CS pins, I have the same problem. The right side displays something, and the left side displays junk. However, there is a correlation. If I swap the CS1/CS2 pins, the left half the of the image shows up on the right. Swap back, and the right side shows up. This tells me that when the display is expecting to write the left side, the data or something gets jumbled.
Something tells me that this is just a bad LCD.
Matt
For reference, my code:
GLCD.h
#include <p18f4550.h>
#define GLCD_Data   PORTD
#define b_GLCD_GCS1 LATCbits.LATC0
#define b_GLCD_GCS2 LATCbits.LATC1
#define b_GLCD_RS   LATEbits.LATE0
#define b_GLCD_RW   LATEbits.LATE1
#define b_GLCD_E    LATEbits.LATE2
#define b_GLCD_On   LATAbits.LATA4
#define b_GLCD_BL   LATBbits.LATB3
#define TRIS_Data    TRISD
#define b_TRIS_GCS1  TRISCbits.TRISC0 //GCS1
#define b_TRIS_GCS2  TRISCbits.TRISC1 //GCS2
#define b_TRIS_RS    TRISEbits.TRISE0 //RS
#define b_TRIS_RW    TRISEbits.TRISE1 //RW
#define b_TRIS_E     TRISEbits.TRISE2 //E
#define b_TRIS_On    TRISAbits.TRISA4 //RST
#define b_TRIS_BL    TRISBbits.TRISB3 //backlight
void Delay(void);
unsigned char GLCD_Read(void);
void Wait_Not_Busy(void);
void GLCD_Write_Cmd(unsigned char data);
void GLCD_Write_Data (unsigned char data);
void ClearScreen(void);
void Init_GLCD(void);
void PutChar(unsigned char data);
unsigned char GLCD_Read_Data(void);
void SetPos(unsigned char x,unsigned char y);
void WritePosition(void);
void plot(unsigned char x,unsigned char y);
void hline(unsigned char x,unsigned char y1,unsigned char y2);
void vline(unsigned char x1,unsigned char x2,unsigned char y);
void box(unsigned char x1,unsigned char y1,unsigned char x2,unsigned char y2);
void PutMessage(static char rom *Message);
void PutLogo(static char rom *logo);
GLCD.C
#include <GLCD.h>
const rom unsigned char Font[96][7];
unsigned char i,XPos,YPos,W;
void plot(unsigned char x,unsigned char y){
unsigned char d;
	if(x>63){
		b_GLCD_GCS1=0;
		b_GLCD_GCS2=1;
		x-=64;
	else
		b_GLCD_GCS1=1;
		b_GLCD_GCS2=0;
	GLCD_Write_Cmd(0x40+x);			//write column address
	GLCD_Write_Cmd(0xb8+(y>>3));	//write row address
	d=GLCD_Read_Data();				//dummy read
	d=GLCD_Read_Data();
	GLCD_Write_Cmd(0x40+x);			//write column address again
	d=d&(0xff-(1<<(y&7)));
	GLCD_Write_Data(d);
void hline(unsigned char x,unsigned char y1,unsigned char y2){
	for(i=y1;i<y2;i++)
		plot(x,i);
void vline(unsigned char x1,unsigned char x2,unsigned char y){
	for(i=x1;i<x2;i++)
		plot(i,y);
	unsigned char x2,unsigned char y2){
	vline(x1,x2,y1);
	vline(x1,x2,y2);
	hline(x1,y1,y2);
	hline(x2,y1,y2);
void Delay(void){
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
unsigned char GLCD_Read(void){
	b_GLCD_E=1;
	Delay();
	W=GLCD_Data;
	b_GLCD_E=0;
	return W;
void Wait_Not_Busy(void){
	TRIS_Data=0xff;
	b_GLCD_RS=0;
	b_GLCD_RW=1;
	if (b_GLCD_GCS1==1 && b_GLCD_GCS2==1){
		b_GLCD_GCS1=0;
		while (GLCD_Read()&0x80);
		b_GLCD_GCS1=1;
		b_GLCD_GCS2=0;
		b_GLCD_GCS2=1;
	else{
	TRIS_Data=0x00;
void GLCD_Write_Cmd(unsigned char data){
	Wait_Not_Busy();
	GLCD_Data = data;
	b_GLCD_RS=0;
	b_GLCD_RW=0;
	b_GLCD_E=1;
	Delay();
	b_GLCD_E=0;
void GLCD_Write_Data (unsigned char data){
	Wait_Not_Busy();
	GLCD_Data = data;
	b_GLCD_RS=1;
	b_GLCD_RW=0;
	b_GLCD_E=1;
	Delay();
	b_GLCD_E=0;
void MoveRight(void){
	if(++XPos==64){
		WritePosition();
	if(XPos==128){
		XPos=0;
		YPos+=8;
		YPos=YPos&0x3f;
		WritePosition();
void WritePosition(void){
	if(XPos>63){
		b_GLCD_GCS1=0;
		b_GLCD_GCS2=1;
	else{
		b_GLCD_GCS1=1;
		b_GLCD_GCS2=0;
	GLCD_Write_Cmd(0x40+(XPos&0x3f));	//column=0
	GLCD_Write_Cmd(0xb8+((YPos&0x3f)>>3));	//row=0
unsigned char GLCD_Read_Data(void){
	Wait_Not_Busy();
	TRIS_Data=0xff;
	b_GLCD_RS=1;
	b_GLCD_RW=1;
	b_GLCD_E=1;
	Delay();
	W=GLCD_Data;
	b_GLCD_E=0;
	TRIS_Data=0x00;
	return W;
void ClearScreen(void){
unsigned char i,j;
	b_GLCD_GCS1=1;
	b_GLCD_GCS2=1;
	for(i=0;i<8;i++){
		GLCD_Write_Cmd(0x40);	//y=0
		GLCD_Write_Cmd(0xb8+i);	//x=0
		for(j=0;j<0x40;j++)
			GLCD_Write_Data(0xff);
	SetPos(0,0);
void Init_GLCD(void){
unsigned char i;
    b_TRIS_GCS1=0;
    b_TRIS_GCS2=0;
    b_TRIS_RS=0;
    b_TRIS_RW=0;
    b_TRIS_E=0;
    b_TRIS_On=0;
    b_TRIS_BL=0;
    b_GLCD_On=1;
	b_GLCD_GCS1=1;
	b_GLCD_GCS2=1;
    b_GLCD_BL=1;
	GLCD_Write_Cmd(0x3f);	//display on
	GLCD_Write_Cmd(0xc0);	//z=0
	ClearScreen();
void PutChar(unsigned char data){
unsigned char i,d;
	if(data<32){
		switch(data){
			case 13:
				XPos=0;
			case 10:
				XPos=0;
				YPos+=8;
				YPos=YPos&63;
		WritePosition();
	else{
		for(i=0;i<7;i++){
			d=Font[data-32][i];
			if(d!=0x55){
				GLCD_Write_Data(d);
				MoveRight();
		MoveRight();
void PutMessage(static char rom *Message){
	while(*Message!=0)
		if(*Message==0x16){
			*Message++;
			XPos=*Message++;
			YPos=*Message++;
			WritePosition();
		else
			PutChar(*Message++);
void PutLogo(static char rom *logo){
unsigned char w,h,bitcount,Byte;
	w=*logo++;
	h=*logo++;
	bitcount=0;
	do{
		for(i=0;i<w;i++){
			if(bitcount==0){
				bitcount=8;
				Byte=*logo++;
			if(Byte&1) plot(XPos,YPos);
			XPos++;
			Byte/=2;
			bitcount--;
		YPos++;
		XPos-=w;
	}while(--h);
void SetPos(unsigned char x,unsigned char y){
	XPos=x;
	YPos=y;
	WritePosition();
const rom unsigned char Font[96][7]={
	0xFF,0xFF,0xFF,0x55,0x55,0x55,0x55,	//	32
	0xFF,0xA0,0xFF,0x55,0x55,0x55,0x55,	//	33	!
	0xF8,0xFF,0xF8,0x55,0x55,0x55,0x55,	//	34	""
	0xEB,0x80,0xEB,0x80,0xEB,0x55,0x55,	//	35	#
	0xD9,0xB6,0x80,0xB6,0xCD,0x55,0x55,	//	36	$
	0x9C,0xEC,0xF7,0x9B,0x9C,0x55,0x55,	//	37	%
	0xC9,0xB6,0xFF,0xDD,0xAF,0x55,0x55,	//	38	&
	0xFB,0xFC,0xFF,0x55,0x55,0x55,0x55,	//	39	'
	0xE3,0xDD,0xBE,0x55,0x55,0x55,0x55,	//	40	(
	0xBE,0xDD,0xE3,0x55,0x55,0x55,0x55,	//	41	)
	0xEB,0xD5,0xE3,0xD5,0xEB,0x55,0x55,	//	42	*
	0xF7,0xF7,0xC1,0xF7,0xF7,0x55,0x55,	//	43	+
	0x7F,0x9F,0x55,0x55,0x55,0x55,0x55,	//	44	,
	0xF7,0xF7,0xF7,0xF7,0xF7,0x55,0x55,	//	45	-
	0xBF,0x55,0x55,0x55,0x55,0x55,0x55,	//	46	.
	0x9F,0xEF,0xF7,0xFB,0xFC,0x55,0x55,	//	47	/
	0xC1,0xAE,0xB6,0xBA,0xC1,0x55,0x55,	//	48	0
	0xFF,0xBD,0x80,0xBF,0xFF,0x55,0x55,	//	49	1
	0x9D,0xAE,0xB6,0xB6,0xB9,0x55,0x55,	//	50	2
	0xDD,0xBE,0xB6,0xB6,0xC9,0x55,0x55,	//	51	3
	0xE7,0xEB,0xED,0x80,0xEF,0x55,0x55,	//	52	4
	0xD8,0xB6,0xB6,0xB6,0xCE,0x55,0x55,	//	53	5
	0xC3,0xB5,0xB6,0xB6,0xCF,0x55,0x55,	//	54	6
	0xFE,0x8E,0xF6,0xFA,0xFC,0x55,0x55,	//	55	7
	0xC9,0xB6,0xB6,0xB6,0xC9,0x55,0x55,	//	56	8
	0xF9,0xB6,0xB6,0xD6,0xE1,0x55,0x55,	//	57	9
	0xEB,0x55,0x55,0x55,0x55,0x55,0x55,	//	58	:
	0x7F,0x97,0x55,0x55,0x55,0x55,0x55,	//	59	;
	0xF7,0xEB,0xDD,0xBE,0x55,0x55,0x55,	//	60	<
	0xEB,0xEB,0xEB,0xEB,0x55,0x55,0x55,	//	61	=
	0xBE,0xDD,0xEB,0xF7,0x55,0x55,0x55,	//	62	>
	0xFD,0xFE,0xAE,0xF6,0xF9,0x55,0x55,	//	63	?
	0xC1,0xBE,0xA2,0xFF,0xB1,0x55,0x55,	//	64	@
	0x83,0xED,0xEE,0xED,0x83,0x55,0x55,	//	65	A
	0x80,0xB6,0xB6,0xB6,0xC9,0x55,0x55,	//	66	B
	0xC1,0xBE,0xBE,0xBE,0xDD,0x55,0x55,	//	67	C
	0x80,0xBE,0xBE,0xDD,0xE3,0x55,0x55,	//	68	D
	0x80,0xB6,0xB6,0xB6,0xBE,0x55,0x55,	//	69	E
	0x80,0xF6,0xF6,0xF6,0xFE,0x55,0x55,	//	70	F
	0xC1,0xBE,0xB6,0xD6,0x8D,0x55,0x55,	//	71	G
	0x80,0xF7,0xF7,0xF7,0x80,0x55,0x55,	//	72	H
	0xBE,0x80,0xBE,0x55,0x55,0x55,0x55,	//	73	I
	0xDF,0xBF,0xBE,0xC0,0xFE,0x55,0x55,	//	74	J
	0x80,0xF7,0xEB,0xDD,0xBE,0x55,0x55,	//	75	K
	0x80,0xBF,0xBF,0xBF,0x55,0x55,0x55,	//	76	L
	0x80,0xFD,0xF3,0xFD,0x80,0x55,0x55,	//	77	M
	0x80,0xF9,0xF7,0xCF,0x80,0x55,0x55,	//	78	N
	0xC1,0xBE,0xBE,0xBE,0xC1,0x55,0x55,	//	79	O
	0x80,0xF6,0xF6,0xF6,0xF9,0x55,0x55,	//	80	P
	0xC1,0xBE,0xAE,0xDE,0xA1,0x55,0x55,	//	81	Q
	0x80,0xF6,0xE6,0xD6,0xB9,0x55,0x55,	//	82	R
	0xD9,0xB6,0xB6,0xB6,0xCD,0x55,0x55,	//	83	S
	0xFE,0xFE,0x80,0xFE,0xFE,0x55,0x55,	//	84	T
	0xC0,0xBF,0xBF,0xBF,0xC0,0x55,0x55,	//	85	U
	0xF0,0xCF,0xBF,0xCF,0xF0,0x55,0x55,	//	86	V
	0xF0,0xCF,0xBF,0xC7,0xBF,0xCF,0xF0,	//	87	W
	0x9C,0xEB,0xF7,0xEB,0x9C,0x55,0x55,	//	88	X
	0xF8,0xF7,0x8F,0xF7,0xF8,0x55,0x55,	//	89	Y
	0x9E,0xAE,0xB6,0xBA,0xBC,0x55,0x55,	//	90	Z
	0x80,0xBE,0xBE,0x55,0x55,0x55,0x55,	//	91	[
	0xFC,0xFB,0xF7,0xEF,0x9F,0x55,0x55,	//	92
	0xBE,0xBE,0x80,0x55,0x55,0x55,0x55,	//	93	]
	0xF7,0xFB,0xFD,0xFB,0xF7,0x55,0x55,	//	94	^
	0xBF,0xBF,0xBF,0xBF,0xBF,0x55,0x55,	//	95	_
	0xFC,0xFB,0xFF,0x55,0x55,0x55,0x55,	//	96	`
	0xDF,0xAB,0xAB,0x87,0x55,0x55,0x55,	//	97	a
	0x80,0xD7,0xBB,0xBB,0xC7,0x55,0x55,	//	98	b
	0xC7,0xBB,0xBB,0xD7,0x55,0x55,0x55,	//	99	c
	0xC7,0xBB,0xBB,0xD7,0x80,0x55,0x55,	//	100	d
	0xC7,0xAB,0xAB,0xB7,0x55,0x55,0x55,	//	101	e
	0xF7,0x81,0xF6,0xFD,0x55,0x55,0x55,	//	102	f
	0x67,0x5B,0x5B,0xA7,0x55,0x55,0x55,	//	103	g
	0x80,0xF7,0xFB,0xFB,0x87,0x55,0x55,	//	104	h
	0xC2,0xBF,0x55,0x55,0x55,0x55,0x55,	//	105	i
	0x7F,0x7B,0x82,0x55,0x55,0x55,0x55,	//	106	j
	0x80,0xEF,0xD7,0xBB,0x55,0x55,0x55,	//	107	k
	0xFE,0x80,0xFF,0x55,0x55,0x55,0x55,	//	108	l
	0x83,0xF7,0xFB,0x87,0xFB,0x87,0x55,	//	109	m
	0x83,0xF7,0xFB,0xFB,0x87,0x55,0x55,	//	110	n
	0xC7,0xBB,0xBB,0xC7,0x55,0x55,0x55,	//	111	o
	0x03,0xE7,0xDB,0xDB,0xE7,0x55,0x55,	//	112	p
	0xE7,0xDB,0xDB,0xE7,0x03,0x55,0x55,	//	113	q
	0x83,0xF7,0xFB,0xFB,0xF7,0x55,0x55,	//	114	r
	0xB7,0xAB,0xAB,0xDB,0x55,0x55,0x55,	//	115	s
	0xFB,0xC1,0xBB,0x55,0x55,0x55,0x55,	//	116	t
	0xC3,0xBF,0xBF,0xDF,0x83,0x55,0x55,	//	117	u
	0xE3,0xDF,0xBF,0xDF,0xE3,0x55,0x55,	//	118	v
	0xC3,0xBF,0xCF,0xBF,0xC3,0x55,0x55,	//	119	w
	0xBB,0xD7,0xEF,0xD7,0xBB,0x55,0x55,	//	120	x
	0xE3,0x5F,0x5F,0x83,0x55,0x55,0x55,	//	121	y
	0x9B,0xAB,0xAB,0xB3,0x55,0x55,0x55,	//	122	z
	0xF7,0xC9,0xBE,0x55,0x55,0x55,0x55,	//	123	{
	0xFF,0x80,0xFF,0x55,0x55,0x55,0x55,	//	124	|
	0xBE,0xC9,0xF7,0x55,0x55,0x55,0x55,	//	125	}
	0xFF,0xFF,0x55,0x55,0x55,0x55,0x55,	//	126	~
	0x01,0x7D,0x7D,0x7D,0x01,0x55,0x55,	//	127
main.c
#include <GLCD.h>
#pragma config WDT = OFF, LVP = OFF, FOSC = HS
const rom unsigned char Logo[];
void main (void){
unsigned char i;
	ADCON1=0x0f;	// all digital
	CMCON=7;		// no comparators
	//while(1)
		Init_GLCD();
		// ascii 22 (0x16) is set position followed by x,y
		PutMessage((rom char*)"\x16\x24\x08 Blueroom\x16\x20\x10 Electronics\n Title:\n Author:\n Date:\n Hardware:");
		PutMessage((rom char*)"\x16\x38\x18Graphic demo.");
		PutMessage((rom char*)"\x16\x38\x20Mike Webb.");
		PutMessage((rom char*)"\x16\x38\x28June 20 2007.");
		PutMessage((rom char*)"\x16\x38\x30Unicorn.");
		box(1,1,126,62);
		SetPos(3,3);
		PutLogo((rom char*)Logo);
		SetPos(127-3-20,3);
	while (1);
const rom unsigned char Logo[]={
	20,21,					// width,height
    0x00,0x06,0x00,0x60,	// raster data - no padding.
    0x00,0x40,0x2F,0x00,
    0xFC,0x03,0x80,0x1F,
    0x00,0xF8,0x01,0x92,
    0x9F,0xF4,0xFB,0xFD,
    0xFE,0xFF,0xE7,0xFF,
    0x7F,0xFF,0xFF,0xEF,
    0xFF,0x7F,0xFC,0xFF,
    0x83,0xFF,0x1F,0xF0,
    0xFF,0x00,0xFE,0x07,
    0xF0,0xFF,0x00,0x60,
    0x00,0x00,0x06,0x00,
    0x60,0x00,0x00,0x06,
	0x00
Re: PIC18F4550 and KS0108 "eBay" 128x64 Display Pr
ebay seller asked me to send this back and he'll refund/replace it for me.
Hope all goes well :/... But I ordered some from BGMicro:
They're only $10...that's a steal.
