Hi....
i m building 150W mosfet inverter...How to fix heatsink to mosfets . And i dont have working priciple of it i downloaded form google images ......,
HEATSINK PLATEN: The required 1cm./5W will make it neccessary to use an Al. plate 5.5" X 6" X .125"Th. using the IRF44's (good choice too). Isolate them
1. I would avoid the LC and go with a 60Hz source MM5369. I noticed the 220VAC
so you are using 50Hz European. The Xtal can be tweaked to that when you set up.
