kandhu26
Member level 5
- Joined
- Sep 7, 2009
- Messages
- 93
- Helped
- 13
- Reputation
- 26
- Reaction score
- 12
- Trophy points
- 1,288
- Location
- chennai / bangalore
- Activity points
- 1,858
i am using 0.30 pin as external interrupt...when i am pressing the switch[interrupt switch] it will go to 5V.[becoz in circuit normally pull down with resistor when the switch is pressed it will go to 5V].first 20 times it was working properly[interrupt was generated]..then suddenly the interrupt is not working[the pin{0.30} itself gone]...my doubt is should i produce interrupt using 5V here...
