djolestojic
Member level 5
I have designed a basic dspic30f4013 based board, according to the datasheet recommendation. It works fine when operated by using ICD2 programmer. But when ICD2 programmer is disconnected from the board, the dspic fails to reset properly.
Does anyone have an idea what could be the problem. I have tried using reset controller, I have issued the reset circuitry proposed by the datasheet, but in every case the controller failed to reset.
Thanks
Thanks
