Results 1 to 4 of 4
    Points: 1,701, Level: 9
    Sep 2004
    49
    1,701
    9
    $random & $urandon - systemVerilong
    How to pass seed information to $random & $urandom so that test scenario can be reproduced.
    Member level 5
    Points: 7,611, Level: 20
    Jan 2000
    90
    7,611
    20
    function int unsigned $random [ (int seed ) ] ;
    function int unsigned $urandom [ (int seed ) ] ;
    The seed is an optional argument.
    Use the same seed to generate the same sequence of random numbers every time.
    A common practice is to use a plusarg at the command line and read it in the testbench ($value$plusargs) and use it as a seed for the random system tasks.
    Advanced Member level 3
    Points: 6,706, Level: 19
    May 2008
    Shang Hai
    972
    6,706
    19
    Re: $random & $urandon - systemVerilong
    each time you run a simulation , the seed will be the same!
    Advanced Member level 2
    Points: 4,734, Level: 16
    Sep 2004
    Bangalore, India
    646
    4,734
    16
    Quote Originally Posted by anant
    SystemVerilog LRM has a detailed section on random stability to which this question kind of belongs to. It dictates that implementations shall be random stable (under few conditions, see LRM for details). However the $random is not part of it, perhaps b'cos it is part of V2K as well. Also SV adds lot more powerful randomization via class, constraints.
    Ajeetha, CVC
    www.cvcblr.com
