Prethiga
Newbie
I am not sure how to solve this issue,
ERROR:
`include "ddr_package.sv"
module Rand_Stimulus( DDR_INTERFACE intf,
TB_INTERFACE tb_intf);
// Set number of operations to be stored in the queue
parameter num_op = 500;
int read_count = 0;
int write_count = 0;
// Use class for randomization
class Packet;
// Random variables
randc bit [63:0] data_r;
randc bit [31:0] addr_r;
randc bit [1:0] op_r;
// Limit values for op to R/W (01 or 10)
constraint c {op_r >= 2'b01;
op_r <= 2'b10;}
endclass
//class Gen_Packet
class Gen_Packet;
rand Packet Packet_array[];
bit [31:0] addr_queue[$];
constraint rw {
foreach (Packet_array)
Packet_array.op_r dist {READ:= 50, WRITE:= 50};
function void post_randomize;
foreach (Packet_array) begin
if ((i == 0) || (addr_queue.size == 0))
Packet_array.op_r = WRITE;
if(Packet_array.op_r == WRITE)
addr_queue = {Packet_array.addr_r, addr_queue};
if ((i > 0) && (Packet_array .op_r == READ ))
Packet_array.addr_r = addr_queue.pop_back;
end
endfunction
function new();
addr_queue.delete;
Packet_array = new[num_op];
Packet_array = new();
endfunction
//function void print_all() ;
//foreach (Packet_array)
// $display ("addr = %h, data = %h, rw = %h", Packet_array.addr_r,
// Packet_array.data_r, Packet_array.op_r);
//endfunction
endclass
// define queue, temp structure union, and class.
input_data_type su[$], Stim_st;
Gen_Packet p;
initial begin
tb_intf.mrs_update <= 1'b0;
// Generate random fields for num_op operations
p = new(); // create a packet
assert (p.randomize())
else $fatal(0, "Gen_Packet::randomize failed");
//p.print_all();
foreach (p.Packet_array) begin
Stim_st.data_wr = p.Packet_array.data_r;
Stim_st.physical_addr = p.Packet_array.addr_r;
Stim_st.rw = p.Packet_array.op_r;
if (Stim_st.rw == 2'b10)
write_count ++;
else
read_count ++;
su.push_front(Stim_st);
end
wait (tb_intf.rw_proc);
do
@ (posedge tb_intf.act_cmd ) begin
tb_intf.data_in = su.pop_back;
end
while (su.size != 0);
end
always_ff @ (intf.clock_t)
begin
if ((!tb_intf.dev_busy) &&(su.size >0 ) && (tb_intf.next_cmd))
tb_intf.act_cmd <= 1'b1;
else
tb_intf.act_cmd <= 1'b0;
end
endmodule
ERROR:
# ** Warning: (vsim-8311) System Verilog assertions are supported only in Questasim.
run
# ** Fatal: ../src/Rand_Stimulus.sv(67): Unable to check out verification license for randomize() feature.
# Time: 0 ps Iteration: 0 Process: /top/stim/#INITIAL#62(#ublk#41953075#62) File: ../src/Rand_Stimulus.sv
# Fatal error in Module Rand_Stimulus at ../src/Rand_Stimulus.sv line 67
# HDL call sequence:
# Stopped at ../src/Rand_Stimulus.sv 67 Module Rand_Stimulus
