NOORPURI
Junior Member level 3
elint receiver
Hi Every One
I need a paper on the design of Elint Receiver. Detail is given below
Document title:
"The digital Electronic Intelligence (ELINT) receiver"
Author(s):
HUBACEK Petr , VESELY Jin ;
Abstract:
This article is focused on the design of the modern digital ELINT receiver. This digital ELINT receiver must be able to process the radar CW and pulse signals in intermediate frequency band 625 - 875 MHz with dynamic range 120dB. These strict requirements on the parameters of receiver ask for the not conventional solution of the receiver structure. Whole receiver is designed as the set of subblocks that are performed partial tasks of signal processing. For example, the receiver contains the wideband receiver, noise receiver and several narrow receivers. The extra attention is paid both the choosing of the suitable A/D convertors and the methods of real-time signal processing in this article. This paper describes the block diagram of the digital ELINT receiver and its operation when the typically radar signal are received and processed. The example of the functional block diagram of this receiver is included.
Journal Title:
Proceedings of SPIE, the International Society for Optical Engineering ISSN 0277-786X CODEN PSISDG.
If any one has this artile kindly upload it. it will be so nice of you
Thanks..
Hi Every One
Document title:
Author(s):
Abstract:
Journal Title:
Thanks..
