m_pourfathi
Full Member level 4
usb flash drive insert disk
Hello all,
I have recently purchased a transcend jetflash 130 4GB flash memory. It was OK last night when I filled it with data and copied all to my computer. but today I cannot use it at all. My computer detects it when it is connected to the computer and I can remove it easily from the safe remove part in the start menu toolbar.
But when I try to access it from My Computer it says: "Please insert a disk into drive H:" and when I try to format it it says: "There is no disk in drive H:. Insert a disk and then try again". Then I tried to format it by DOS. using "format H:" but is says : "Insert new disk for drive H:"!!!! I even tried to use "Data Doctor Recovery Pen drive" to recover it and still, there was no luck!!
What should I do now? do you think there's something wrong with the hardware itself? or maybe it's file system has been corrupted somehow. do you guys have any softwares for accessing the flash memory low-level?
Regards,
m_pourfathi
Hello all,
Regards,
m_pourfathi
