+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Member level 5
    Points: 2,527, Level: 11
    Achievements:
    7 years registered
    Join Date
    Oct 2007
    india
    Posts
    94
    Points
    2,527
    Level
    11
    what are the impacts of transistor mismatching?????
    what are the problems that com a cross if there is no matching? Is it causes to chip failure, what are the adverse effects??
    •   AltAdvertisement
  2. #2
    Member level 1
    Points: 2,016, Level: 10
    Join Date
    May 2006
    India
    Posts
    40
    Points
    2,016
    Level
    10
    Re: what are the impacts of transistor mismatching?????
    Mismatch not cause chip failure, it may give u wrong results for ur inputs
    •   AltAdvertisement
  3. #3
    Member level 5
    Points: 2,034, Level: 10
    Achievements:
    7 years registered
    Join Date
    Jul 2006
    Bangalore(INDIA)
    Posts
    83
    Points
    2,034
    Level
    10
    Yes.... mismatching means amount of signal reaching at particular point at given time will be different which impact the circuit performance.
    •   AltAdvertisement
  4. #4
    Member level 5
    Achievements:
    7 years registered
    Join Date
    Oct 2007
    india
    Posts
    94
    Points
    2,527
    Level
    11
    In general transistor mismatch refers to the measurable differences in the electrical proporties such as Ic, β, gm between two identically designed and layout devices. Analog designers think a lot about matching.
    Basic operations of some circuits like ADCs directly depends on matching.
    The CMRR of an op-amp limited by matching since it uses differential amlifier, and offsets greatly degrade the performance of bandgap references.
    Mismatch leads to device-device threshold voltage variations.
    thanks & regards,
    santhosh
