liletian
Full Member level 6
Hi Guys
I am studying RFDE software examples, the question is how to set up a marker?
For example,in HB simulation, I have two frequencies, and one sweep parameter(VinputdB),then the output variables will be a function of VinputdB, so how can I set up a marker so when I move marker, the plot will update automatically as the VinputdB changes. The example was in RFDE example RFIC_BJT_Mixer->MixConversionGain, also can anyone explain the following expression?
vs(Spectrum[VinputIndex,::],freq[VinputIndex,::])
also, in the same example, what is spectrum, dB volts? The define function is
Spectrum=20*log(mag(IF_p-IF_N)+1e-20)
so what is spectrum, dB volts?
It is so confusing.
Thanks a lot for your reply
It is so confusing.
