cadence ic6.10 installation on ubuntu7.10
chaoschin
Newbie level 3
ic6 cadence
I have installed the cadence ic6.10 on the ubuntu7.10,but I have seen some problem,when I type the commond "lmgrd -c license.dat"
that's erro
18:31:17 (lmgrd) Can't make directory /usr/tmp/.flexlm, errno: 2(No such file or directory)
18:31:17 (lmgrd) Can't open /usr/tmp/.flexlm/lmgrdl.31958, errno: 2
when I make the director /usr/tmp/.flexlm .the first erro was fixed.but "Can't open /usr/tmp/.flexlm/lmgrdl" can't fixed.
that's my ev
alias lmli='/home/eda/ic610/tools/bin/lmgrd -c /home/eda/ic610/share/license/license.dat'
export OA_HOME=/home/eda/ic610/OA
export CDS_ROOT=/home/eda/ic610
export CDS_LIC_FILE=5280@chaos-desktop
export LM_LICENSE_FILE=$CDS_ROOT/share/license/license.dat
export CDS_Netlisting_Mode=Analog
export PATH=$CDS_ROOT/tools/bin:$CDS_ROOT/tools/dfII/bin:$PATH
export MOZILLA_HOME=/usr/bin/netscape
Do the ubuntu7.10 support the cadence ic6.10?
Added after 8 minutes:
I prepare to install the opensuse 10.2. someone had installed the cds ic6.10 on opensuse10.2.and successful.
I don't know what 's the problem.
lmgrd cadence
I would recommend you stick with RPM based distribution for EDA.
Experience talking.
Ubuntu guys don't do the hardcore development and have no idea what YOU really need as a non standard user.
Stick with either Red Hat based distribution or a Suse one.
If your friend has suse, use suse at least he/she will support you in difficult times.
cadence ic6
I have met the same problem,
Have you resolved?
How to fix this error?
Thanks!
that's erro
that's my ev
export CDS_LIC_FILE=5280(at)chaos-desktop
install cadence ic6
try
/home/eda/ic610/tools/bin/lmgrd -c /home/eda/ic610/share/license/license.dat -l /tmp/cadence.log
cadence license.dat
diffrence?
cadence lmgrd
can anyone let me know that IC5.1 is compatible with SUSE-9 OS
ubuntu usr/tmp .flexlm cannot create directory
how can i install ic6 at centos. i didn't know about command line. pls help me ! i have to install for my study
:cry:
cadence ic6 os
Create a symbolic link to /tmp in /usr so it looks like:
/usr/tmp -> /tmp
Then all your license servers should start without a problem.
Can some one tel me, how to solve this error. I am having this problem with every disto i tried with.
Detecting InstallScape for lnx86...
Checking InstallScape on media...
/bin/tar: Skipping to next header
/bin/tar: Archive contains obsolescent base-64 headers
/bin/tar: ./iscape/VERSION.lnx86: Not found in archive
/bin/tar: Error exit delayed from previous errors
/bin/cat: /tmp/is3276/iscape/VERSION.lnx86: No such file or directory
You must have write permissions to /cad/is //I was installing this as a root
There must be atleast 80 MB of disk space available in // i have 18 GB free space
/cad/is
Exiting...
/cad/is
Exiting...
I have the same problem!! Can anyone provide a solution please???
