+ Post New Thread + Mark as Solved
Results 1 to 2 of 2
  1. #1
    ahmadagha23
    AES IP-core for fpga???
    Dear friends
    where can I find (download) FREE VHDL code ( RTL IP-core) for AES encryption algorithm implementation on XILINX FPGA?
    can I implement the ip cores for spartan2 on spartan for example the following IP:
    http://www.erst.ch/english/ip_cores/aes/aes.html
    regards
    •   AltAdvertisement
  2. #2
    Full Member level 5
    Points: 3,775, Level: 14
    Achievements:
    7 years registered
    Join Date
    Jun 2006
    Middle Earth
    Posts
    296
    Points
    3,775
    Level
    14
    Re: AES IP-core for fpga???
    http://www.opencores.org/projects.cg...es_crypto_core It has a few other AES implementations too, check them out.
    Also which spartan2 chip are you using? It depends on the number of gates available.
