Adjustable voltage controlled current source with negative values
leilamontazeri
Newbie level 1
I have a MEMS mirror which can tilt based on the input current. The current can vary between -15mA to +15mA in order to change the angle of the mirror from -15 to +15 degree. Now, I need to have an adjustable voltage-controlled current source that can also provide negative values. I prefer to use Raspberry pi or Arduino. I appreciate any help.
You need a Current Charge Pump that sources and Sinks a current. I believe this current pump will change the current linearly between -15 to 15 mA Right ?
In this case, you should find a solution Voltage-to-Current Converter to drive this Charge Pump.
Depends on the input resistance of this MEMS (is it linear? I have never used one), but you could use maybe a resistor and a variable voltage source to create the necessary current values.
The voltage source needs negative value too, with dual supply it is easy. If you don't have dual supply maybe a bridge-circuit from stereo potentiometer or a differentially variable voltage source could solve it.
It would help I think if you shared more data about the MEMS and your application, how accurate tuning you need, etc.
You could likely use a Howland op amp current source, since it can generate plus and minus currents.
What is the resistance of the load?
What power supply voltages do you have available?
Here's the LTspice simulation of a representative Howland current source that generates ±15mA pk constant-current into a load:
Notice that the load current (yellow trace) remains constant as the load resistance increases (red trace) until saturation.
For the op amp and supply voltage shown, it saturates at a load resistance of 1k ohm and above.
The input is fully differential, and either input can be connected to ground, as desired.
If you need to derive a -5v supply from an existing +5v supply then this is a popular method:
555 iC positive pulses to negative V quadrupler makes +-5V biploar supply 15mA.png
For the load you install your circuit which needs between +5 and -5v (referenced to 0v ground).
The low-ohm resistor at the 555 output is optional although it is a good idea in order to reduce spikey jolts in the system.
  • 555 iC positive pulses thru negative V quadrupler makes +-5V biploar supply 15mA.png
Here's a corrected schematic with a higher voltage op amp.
The LMC6484 is only rated for 16V max.
