Help in diode code v6 12 Panasonic Plasma TH-P42X30D
hemant.yash
Newbie level 3
Repairing Panasonic Plasma TH-P42X30D TV
Came across few V6 12 schottky diode in Power Supply (P Card)
one of them is Short as per Meter when checked which is causing the problem in starting TV
Any help with the code - v6 12 ?
its value and part number
Is the marking on the part 'V6'? What format of package is this ? Post a picture please
Posting the Pic
It is
diode (1).jpgdiode (2).jpg v6 12
https://imgur.com/odCKMeS
https://imgur.com/UNWL268
I have the service manual here but some parts are only referenced as complete boards rather than individual components. What are the component references numbers on the PCB and I'll see if they are in the parts list.
Brian.
this is the picture of P Board
and I have circled with red marker there are multiple V6 12 labled diode
Brian.
I've attached the schematic.
Unfortunately, it doesn't list the part numbers and I can't read the board references clearly except D104. As it seems to be only to protect against over current in the switching device it is almost certainly nothing special, probably a normal silicon small dower diode.
Brian.
  • panasonic_mpf6907_pcpf0272_sch.pdf
