FlyingDutch
Advanced Member level 1
- Joined
- Dec 16, 2017
- Messages
- 457
- Helped
- 45
- Reputation
- 92
- Reaction score
- 55
- Trophy points
- 28
- Location
- Bydgoszcz - Poland
- Activity points
- 4,933
Issues during attemp of implementation of "Matrix multiplication" Verilog project
Hello,
I am trying to implement Verilog (actually: mixed VHDL and Verilog) project for matrix multiplication from this WWW page:
https://www.fpga4student.com/2016/12/fixed-point-matrix-multiplication-in-Verilog.html
The input and output data are stored in BRAMs from FPGA circuit. My target FPGA is Spartan6 (XC6SLX9) - here is link to FPGA board I am using:
https://numato.com/docs/mimas-v2-spartan-6-fpga-development-board-with-ddr-sdram/
I am using ISE 14.7 Webpack on Windows. My problem is that I don't know how to generate needed BRAMs using "Xilinx Core Generator". I earlier generated BRAMS using "Xilinx Core Generator" from "zero", but I don't know how to do that from existing code - given on project WWW page.
There is also used Verilog library for fixed-point math operations. I just added code from this page to ISE .project:
https://www.dropbox.com/sh/inydmxlfz7ojquq/AADMZ9Jg_eZDjJFbFcgOcpcka/trunk?dl=0&subfolder_nav_tracking=1
and this library is working properly. I also added code of used BRAMs to the ISE project entities:
During synthesis phase *.ngc files are created by software. Verilog module named "matrix_multiplication" is my top module. Synthesis phase of implementing top module is ended without errors, but during "translation phase" I have three errors related to BRAMs components.
Here are translate errors:
ANd here is output from ISE console (only translate phase):
Could somebody help me with these issues?
Here is zipped ISE 14.7 project, and is second file zipped console output (all phases).
Thanks in advance and regards.
Hello,
- Matrix_A
- ROM
- matrix_out
ERROR:NgdBuild:604 - logical block 'matrix_A_u' with type 'Matrix_A' could not
be resolved. A pin name misspelling can cause this, a missing edif or ngc
file, case mismatch between the block name and the edif or ngc file name, or
the misspelling of a type name. Symbol 'Matrix_A' is not supported in target
'spartan6'.
ERROR:NgdBuild:604 - logical block 'matrix_B_u' with type 'ROM' could not be
resolved. A pin name misspelling can cause this, a missing edif or ngc file,
case mismatch between the block name and the edif or ngc file name, or the
misspelling of a type name. Symbol 'ROM' is not supported in target
'spartan6'.
ERROR:NgdBuild:604 - logical block 'matrix_out_u' with type 'matrix_out' could
not be resolved. A pin name misspelling can cause this, a missing edif or ngc
the misspelling of a type name. Symbol 'matrix_out' is not supported in
target 'spartan6'.
Process "Synthesize - XST" completed successfully
Started : "Translate".
Running ngdbuild...
Command Line: ngdbuild -intstyle ise -dd _ngo -nt timestamp -i -p xc6slx9-tqg144-3 matrix_multiplication.ngc matrix_multiplication.ngd
Command Line: E:\Xilinx\14.7\ISE_DS\ISE\bin\nt\unwrapped\ngdbuild.exe -intstyle
Reading NGO file
"C:/Users/MGabryelski.FAM/Spartan6/Matrix4DimMultiplyVerilog/matrix_multiplicati
on.ngc" ...
Loading design module
"C:\Users\MGabryelski.FAM\Spartan6\Matrix4DimMultiplyVerilog/Matrix_A.ngc"...
"C:\Users\MGabryelski.FAM\Spartan6\Matrix4DimMultiplyVerilog/ROM.ngc"...
Gathering constraint information from source properties...
Done.
Resolving constraint associations...
Checking Constraint Associations...
Done...
Checking expanded design ...
'spartan6'.
'spartan6'.
target 'spartan6'.
Partition Implementation Status
No Partitions were found in this design.
NGDBUILD Design Results Summary:
Number of errors: 3
Number of warnings: 0
Total REAL time to NGDBUILD completion: 1 sec
Total CPU time to NGDBUILD completion: 1 sec
One or more errors were found during NGDBUILD. No NGD file will be written.
Writing NGDBUILD log file "matrix_multiplication.bld"...
Process "Translate" failed
