Nancy1985
Friends,
I want to use power MOSFET IRF530 as a switch to turn ON/OFF a (12V, 5W) heater coil. The gate is driven by about 4 dc voltage from another low power IC. This pin however cannot source more than 1mA current. In addition this IC is driven by 5V voltage source which is different from the 12V DC supply that drives the heater. I would like someone to let me know if:
1) Do I need separate gate driver for the MOSFET or the 4Vdc is sufficient to turn on the IRF530 to allow the required 2.4 A current by heating coil?
2) Switching speed is not a very critical. Even if the IRF530 takes about a second to turn ON/OFF, it is fine. But to protect that can I use unity gain buffer before the gate?
