What's the best THD for UPS?
m_electronic
Newbie level 3
I need to use a ups for a pump.
But what's the best THD for it?(5% is a good for it?)
Re: Best THD for UPS
yes if you can achieved that 5percent is ok.
Thanks ,
What's different between online and offline ups? which one is better?
In my understanding, online UPS is referring to a design, where the load is permanently powered through the inverter. So the load will be supplied without any voltage drop in case of a power loss. It's mainly required for electronic equipment, that doesn't tolerate even short voltage drops, e.g a computer.
IEC recommends less THD less than 8%.
