Maximum frequency Calculation
kumar_eee
Advanced Member level 3
Bangalore,India
What will be the Maximum clock frequency of the circuit?
I'm confused on which edge we will calculate the setup & hold for the latch. I guess it should be the trailing one. Any suggestions?
Assuming clk duty cycle is D. So t_cq + t_comb + t_latchsetup < t_clkperiod * D + t_Delay. From this, you can get the max allowed freqency.
Hi Kumar,
T1 T2 T3 T4
T1 is the launching edge of data
T1+thold --> T2-tsetup is the period available for data to be stable...as latch is transparent from T1-T2.
So setup check will be done at T2 and hold will be done at as usual T1
Min time period is
t(cell delay of flop) + t(combi delay)< T(clk period)*(1/2) - t(setup of latch) + t(skew)
so as ebuddy pointed out we can replace 1/2 in the above equation with duty cycle for generalized equation as in the above calculation I have assumed 50% duty cycle...
The fig is not so clear so uploading the attachment
Cheers,
  • New Text Document.txt
