[SOLVED] LCD 8 bit in Assembly
vishy71
Full Member level 2
Iran
hi
I find some codes to use 8 bit LCD but I can't understand!
can you write me a code and discribe it?
thanks
org 00h
ljmp main
org 0100h
main: mov p0,#00h
mov a,#30h
lcall cmdrt
lcall delay
mov a,#30h
lcall cmdrt
lcall delay
mov a,#38h
lcall cmdrt
lcall delay
mov a,#06h
lcall cmdrt
lcall delay
mov a,#0fh
lcall cmdrt
lcall delay
mov a,#80h
lcall cmdrt
lcall delay
main1:
mov a,#01h
lcall cmdrt
lcall delay
mov a,#'W'
lcall dw1
lcall delay
mov a,#'E'
lcall dw1
lcall delay
mov a,#'L'
lcall dw1
lcall delay
mov a,#'C'
lcall dw1
lcall delay
mov a,#'O'
lcall dw1
lcall delay
mov a,#'M'
lcall dw1
lcall delay
mov a,#'E'
lcall dw1
lcall delay
dw1:
setb p2.0
lcall mdata
ret
cmdrt:
clr p2.0
lcall mdata
ret
mdata:mov p0,a
setb p2.1
nop
nop
nop
nop
nop
nop
nop
nop
clr p2.1
clr p2.0
ret
delay:mov r4,#70h
lpp2:mov r3,#0ffh
lpp1:djnz r3,lpp1
djnz r4,lpp2
ret
delay1:mov r4,#0ffh
lpp22:mov r3,#0ffh
lpp11:djnz r3,lpp11
djnz r4,lpp22
ret
end
analyse this .. its very simple
oh *** I forget say please in MPLAB!with PIC!sorry but really thanks for your code!
---------- Post added at 18:41 ---------- Previous post was at 18:40 ----------
***!it's really hard!
---------- Post added at 18:41 ---------- Previous post was at 18:41 ----------
ahora! help me!
---------- Post added at 18:42 ---------- Previous post was at 18:41 ----------
---------- Post added at 18:42 ---------- Previous post was at 18:42 ----------
ahora mazda
i think this is for 8085
I sent you a full project and sim for a Lcd the other day - is there a problem with it ?
8 Bit lcd refers to the way data is sent out to the lcd from the pic - in that mode the 8 bits of data is sent on 8 parallel lines to the lcd and it also uses 2 or 3 lines to contrl the lcd.
The way most people use is 4 Bit mode which means with the 2 or 3 control lines they only have to use one whole port such as PortB or D.
4 bit mode is basically the same as 8 bit, just that is sends the 8 bits of data to the lcd as 2 lots of 4 bits, so saving 4 i/o lines on the Pic.
The code I sent shows how to easily insert message text into you code - not too hard to follow hopefully.
However the actual LCD routines are quiet complex for the beginner to follow even with notes, so would suggest you either just accept them for now or if you do wish to fully understand the lcd routines follow these tutorials.EPE FAQs & Resources
Reactions: vishy71
    vishy71
oh!sorry
no! that was really strong program but 4bit! right?
oh!sorry
Yes that program is 4 bit, if thats what you mean ?
Did you get the sample programs I sent in you other thread to work on your PC ?
From your other current post seems you are struggling to start learning.
Perhaps Micros are a bit advanced for you at the moment, unless you are very keen on doing the programming side of things ?
You mentioned the 555 Timer chip, well thats an ideal one to start learning with, cheap to buy, can easily be built on a small breadboard if you are not handy with a soldering iron.
You can make so many different projects with them and just a few different cheap components.
Just download the Datasheet as a reference , then search for '555 Timer tutorials ' and you will get loads - just follow one that looks easy to you and then start learning by actually building something - all theory can be so boring..
Reactions: vishy71
    vishy71
hi
well! if you don't know 555timer then you can not get it's datasheet! I mean is there any books about IC and what's their duty
and how we can use them!
for example I know 4017 IC and I know how can I use it!so I can take datasheet.
but if I don't know this IC how can I solve my problem about driving 7-segments?
hi
? - you simply Google '555 Datasheet' and download it ..
I is there any books about IC and what's their duty
There are so many chips around no one can cover them in detail, there are lots of books but which ones will satisfy your needs is hard for others to judge.
Again look to the web , there are so many good tutorials out there like the 555 ones I mentioned yesterday.
Are you meaning driivng with logic chips or from a micro ?
Again there are loads of examples/ projects on the web using both methods.
here is a good on for the micro.
Nigel's PIC Tutorial Page
Reactions: vishy71
    vishy71
I am really sorry! you can't understatnd my mean!
you can see this code if u can understand
void LCD_init()
LCD_command(0x38 );
delay(10);
LCD_command(0x06);
delay(10);
LCD_command(0x0C);
delay(10);
LCD_command(0x02);
delay(10);
LCD_command(0x01);
delay(10);
void LCD_command(unsigned char comm)
PORTB=comm;
rs = 0; //register select=command
delay(1);
rw = 0; //write
delay(1);
en = 1;
delay(10); //Enable H->L
en = 0;
delay(10);
void Sendchar(unsigned char dat)
PORTB=dat;
rs = 1; //register select=data
delay(1);
rw = 0; //write
delay(1);
en = 1;
en = 0;
delay(10);
void main()
LCD_init();
Sendchar('s');
Reactions: vishy71
    vishy71
try to find datasheet for LCD, it will help a lot. It's very tricky, because LCD with the same controller can have different part number.
Reactions: vishy71
    vishy71
Hi
is this assembly code?it's like as the mikroC codes!
I think you need to understand the LCD commands first, and how they control the display and then the code may be easier to follow.
This link explains the LCD commands and command sequences, **broken link removed**
This link is for a Microchip application note.**broken link removed**, it explains the the process in the code.
Reactions: vishy71
    vishy71
With 4-bit mode you can save I/O lines and it's NOT complex to program. So most people use 4bit mode for LCD; you can find very good introduction and sample code in Microchip-Assembly here;
PIC Tutorial* Three - LCD Modules
---------- Post added at 04:43 ---------- Previous post was at 04:41 ----------
Reactions: vishy71
    vishy71
