Walsh code generation using VHDL on FPGA board
chrisnonso
Hello all,
Please I am trying to design a walsh code of length 8 on FPGA using VHDL codes. I am using 2 T-flip flops, 3 AND gates and 1 OR gate to implement this design. I have been unsuccessful and really need some help as I am new to using VHDL code language. What I have so far shown below synthesizes but the simulation report does not reproduce the accurate result. Any help will be greatly appreciated. Thanks.
Library ieee;
USE ieee.std_logic_1164.ALL;
USE ieee.std_logic_arith.ALL;
ENTITY walsh8 IS
PORT(clk: IN STD_LOGIC;
RESET: IN STD_LOGIC;
u0: IN STD_LOGIC;
u1: IN STD_LOGIC;
u2: IN STD_LOGIC;
OUTPUT: OUT STD_LOGIC);
END walsh8;
ARCHITECTURE fpga OF walsh8 IS
SIGNAL Q1: STD_LOGIC;
SIGNAL Q2: STD_LOGIC;
SIGNAL T : STD_LOGIC := '0';
BEGIN
PROCESS(clk, RESET)
BEGIN
IF (reset = '1') THEN
T <= '0';
ELSIF (clk='1' AND clk'EVENT) THEN
T <= NOT T;
END IF;
END PROCESS;
PROCESS (clk, RESET)
BEGIN
IF (RESET = '1') THEN
Q1 <= '0';
Q2 <= '0';
ELSIF(clk='1' AND clk'EVENT) THEN
Q1 <= T XOR Q1;
Q2 <= Q1 XOR Q2;
END IF;
OUTPUT <= ((u0 AND T) OR (u1 AND Q1) OR (u2 AND Q2));
END PROCESS;
END fpga;
Hello all,
Library ieee;
ENTITY walsh8 IS
u0: IN STD_LOGIC;
u1: IN STD_LOGIC;
u2: IN STD_LOGIC;
END walsh8;
BEGIN
PROCESS(clk, RESET)
BEGIN
T <= '0';
T <= NOT T;
END IF;
END PROCESS;
BEGIN
Q1 <= '0';
Q2 <= '0';
Q1 <= T XOR Q1;
Q2 <= Q1 XOR Q2;
END IF;
END PROCESS;
END fpga;
Greetings,
Tell us, what vhdl software are you using? Altera Quartus???
Best regards...
URGENT!!! FOR PROJECT!
Hello everyone,
I posted a problem I am currently having with my project using VHDL on FPGA. I am using Altera DE2-70 board with Quartus II 9.1 web edition. I have worked more on the problem and now it synthesizes and simulates however I am not getting the expected result. I get a few warnings after analysis and synthesis. Please review my program below and make suggestions please. Its urgent since it is my project that is due in another 48 hours. Thanks for your input.
Library ieee;
ENTITY walsh8 IS
u0: IN STD_LOGIC;
u1: IN STD_LOGIC;
u2: IN STD_LOGIC;
OUTPUT: OUT STD_LOGIC_VECTOR (7 DOWNTO 0));
END walsh8;
SIGNAL Q1: STD_LOGIC_VECTOR (7 DOWNTO 0);
SIGNAL Q2: STD_LOGIC_VECTOR (7 DOWNTO 0);
SIGNAL T : STD_LOGIC_VECTOR (7 DOWNTO 0);
SIGNAL X : STD_LOGIC_VECTOR (7 DOWNTO 0):=(OTHERS => '0');
SIGNAL Y : STD_LOGIC_VECTOR (7 DOWNTO 0):=(OTHERS => '0');
SIGNAL Z : STD_LOGIC_VECTOR (7 DOWNTO 0):=(OTHERS => '0');
BEGIN
PROCESS(clk,RESET,T)
BEGIN
T <= "00000000";
T <= "01010101";
END IF;
END PROCESS;
PROCESS (clk,RESET,Q1,Q2)
BEGIN
Q1 <= "00000000";
Q2 <= "00000000";
Q1 <= T XOR Q1;
Q2 <= Q1 XOR Q2;
END IF;
END PROCESS;
PROCESS (clk,RESET,u0,u1,u2,X,Y,Z)
BEGIN
IF (clk = '1' AND clk 'EVENT) THEN
IF u0 <= '0' THEN
X <= "00000000";
ELSIF u0 <= '1' THEN
X <= "11111111";
END IF;
IF u1 <= '0' THEN
Y <= "00000000";
ELSIF u1 <= '1' THEN
Y <= "11111111";
END IF;
IF u2 <= '0' THEN
Z <= "00000000";
ELSIF u2 <= '1' THEN
Z <= "11111111";
END IF;
END IF;
END IF;
END PROCESS;
OUTPUT <= ((X AND T) OR (Y AND Q1) OR (Z AND Q2));
END fpga;
Info: *******************************************************************
Info: Running Quartus II Analysis & Synthesis
Info: Command: quartus_map --read_settings_files=on --write_settings_files=off walsh8 -c walsh8
Info: Found 2 design units, including 1 entities, in source file walsh8.vhd
Info: Elaborating entity "walsh8" for the top level hierarchy
Warning: Output pins are stuck at VCC or GND
Warning (13410): Pin "OUTPUT[1]" is stuck at GND
Warning (13410): Pin "OUTPUT[3]" is stuck at GND
Warning (13410): Pin "OUTPUT[5]" is stuck at GND
Warning (13410): Pin "OUTPUT[7]" is stuck at GND
Info: 12 registers lost all their fanouts during netlist optimizations. The first 12 are displayed below.
Info: Register "X[1]" lost all its fanouts during netlist optimizations.
Info: Register "X[3]" lost all its fanouts during netlist optimizations.
Info: Register "X[5]" lost all its fanouts during netlist optimizations.
Info: Register "X[7]" lost all its fanouts during netlist optimizations.
Info: Register "Y[1]" lost all its fanouts during netlist optimizations.
Info: Register "Y[3]" lost all its fanouts during netlist optimizations.
Info: Register "Y[5]" lost all its fanouts during netlist optimizations.
Info: Register "Y[7]" lost all its fanouts during netlist optimizations.
Info: Register "Z[1]" lost all its fanouts during netlist optimizations.
Info: Register "Z[3]" lost all its fanouts during netlist optimizations.
Info: Register "Z[5]" lost all its fanouts during netlist optimizations.
Info: Register "Z[7]" lost all its fanouts during netlist optimizations.
Info: Implemented 21 device resources after synthesis - the final resource count might be different
Info: Implemented 5 input pins
Info: Implemented 8 output pins
Info: Implemented 8 logic cells
Info: Quartus II Analysis & Synthesis was successful. 0 errors, 5 warnings
Info: Peak virtual memory: 219 megabytes
Info: Processing ended: Sun Dec 05 14:50:36 2010
Info: Elapsed time: 00:00:03
Info: Total CPU time (on all processors): 00:00:03
BEGIN
T <= "00000000";
T <= "01010101";
END IF;
END PROCESS;
I think this is wrong , you use T in your sensitivity list when you are actually modifying T inside the process, there in no need for T to be there.
Also all the processes are executed in parallel and whatever change they do to a signal will not be valid until the next rising edge of the clock.
So when you do something like
Q1 <= T XOR Q1;
Q2 <= Q1 XOR Q2;
inside your process i hope you are aware that Q1 will be assigned the new value in the next rising edge of the clk and that Q2 in the next line will be calculated using the value that Q1 had when the process was triggered and not the new value that you have just assigned.
The same applies as i said to different processes, when you change T in a rising edge then all the processes triggered in the same rising edge will use the value of T as it was before the change.
Alex
    V
its not ideal -- the process will get re-evaluated each time T changes, but a change in T will not trigger either the "if reset" or the "else if rising_edge clk" portions. There is no need to re-evaluated the process whenever T changes. Still, it doesn't actually affect synthesis, as synthesis will ignore the sensitivity list even if such wouldn't agree with sim. And it doesn't change the sim results, as the re-evaluation doesn't update any signals -- it just wastes time.
I'm not sure what "if u1 <= '1' then" does in this context.
there probably is a fundamental issue with your code as well -- notice that T is either 00000000 or 01010101. Thus bits 1,3,5,7 are always 0. Q1 <= T xor Q1, where Q1 is equal to 0000000. xor'ing with T will give either 00000000 or 01010101. The same goes for Q2. finally, you use an AND mask on each of the values (again, giving either 00000000 or 01010101) and or the results together (still 00000000 or 01010101). As a result, the tools have removed much of the design -- and bits 1,3,5,7 can never be set to a non-zero value.
The warnings are just telling you that these bits are never changed and have been optimized. In most designs, all bits of an output are used, though sometimes they are not (eg, extra sign bits). Thus it is a warning and not an error..
    V
Hello everyone,
Library ieee;
ENTITY walsh8 IS
u0: IN STD_LOGIC;
u1: IN STD_LOGIC;
u2: IN STD_LOGIC;
END walsh8;
BEGIN
BEGIN
T <= "00000000";
T <= "01010101";
END IF;
END PROCESS;
BEGIN
Q1 <= "00000000";
Q2 <= "00000000";
Q1 <= T XOR Q1;
Q2 <= Q1 XOR Q2;
END IF;
END PROCESS;
BEGIN
IF u0 <= '0' THEN
X <= "00000000";
X <= "11111111";
END IF;
IF u1 <= '0' THEN
Y <= "00000000";
Y <= "11111111";
END IF;
IF u2 <= '0' THEN
Z <= "00000000";
Z <= "11111111";
END IF;
END IF;
END IF;
END PROCESS;
END fpga;
You are using this wrong:
IF u2 <= '0' THEN instead IF u2='0' THEN
because the expression is assignment, the correct is comparative expression, you wanna know if u2 is equal to '0' in this code...
change others.... like this
Best regards
---------- Post added at 01:24 ---------- Previous post was at 01:21 ----------
One more thing,
what exactly you're trying this vhdl do? specially in the last process.
I want the VHDL code to give results of a walsh code of length 8. In otherwords u0, u1, and u2 are user controlled such that if the code is correct then when u2u1u0 in that order are as follows I should get the following result:
walsh code 1: u2 = 0 u1 = 0 u0 = 0 then my result should be 00000000
walsh code 2: u2 = 0 u1 = 0 u0 =1 then 01010101
walsh code 3: u2 = 0 u1 = 1 u0 = 0 then 00110011
walsh code 4: 0 1 1 then 01100110
walsh code 5: 1 0 0 then 00001111
walsh code 6: 1 0 1 then 01011010
walsh code 7: 1 1 0 then 00111100
walsh code 8: 1 1 1 then 01101001
This is what am trying to do. Thanks so far for the input. I will to implement the suggestions made. Thanks alot.
Well, you can try something like this
process (clk,reset,u0,u1,u2)
begin
if(reset=1) then
u0<=0;
u1<=0;
u2<=0;
elsif(clk'event and clk=1) then
--walsh code 1: u2 = 0 u1 = 0 u0 = 0 then my result should be 00000000
if(u2=0 and u1=0 and u0=0) then
Z <= "00000000";
--walsh code 2: u2 = 0 u1 = 0 u0 =1 then 01010101
elsif (u2=0 and u1=0 and u0=1) then
Z <= "01010101";
--walsh code 3: u2 = 0 u1 = 1 u0 = 0 then 00110011
Z <= "00110011";
--walsh code 4: 0 1 1 then 01100110
elsif (u2=0 and u1=1 and u0=1) then
Z <= "01100110";
--walsh code 5: 1 0 0 then 00001111
elsif (u2=1 and u1=0 and u0=0) then
Z <= "00001111";
--walsh code 6: 1 0 1 then 01011010
elsif (u2=1 and u1=0 and u0=1) then
Z <= "01011010";
--walsh code 7: 1 1 0 then 00111100
elsif (u2=1 and u1=1 and u0=0) then
Z <= "00111100";
--walsh code 8: 1 1 1 then 01101001
Z <= "01101001";
end if;
end if;
end process;
or something like this... try... i cant know test in quartus ii... im bussy
Best regards... dont forget mark this and other if it helps you
    V
try this code
Library ieee;
ENTITY walsh8 IS
u :IN STD_LOGIC_vector(2 downto 0);
OUTPUT: OUT STD_LOGIC_vector(7 downto 0));
END walsh8;
BEGIN
PROCESS(clk, RESET)
BEGIN
OUTPUT<= (others=>'0');
case u is
when "000" => OUTPUT <="00000000";
when "001" => OUTPUT <="01010101";
when "010" => OUTPUT <="00110011";
when "011" => OUTPUT <="01100110";
when "100" => OUTPUT <="00001111";
when "101" => OUTPUT <="01011010";
when "110" => OUTPUT <="00111100";
when "111" => OUTPUT <="01101001";
when others => null;
end case;
END IF;
END PROCESS;
END fpga;
i have just made the input a 3 bit vector for easier implementation of the case.
Alex
