What is the Voltage at Floating node ??
MammPp
Junior Member level 2
Dear All,
I have some question about floating node. As the following picture,
If I set V1 to be Vdd all the time.
and V2 is Vdd at the first period, then set V2 is 0 (Which is close NMOS)
My question is, what is the value of the voltage at node C ?
and if V2 is zero, the other transistor, which node C is gate of them, is on/off ?
Thank you so much for your help
MammPp
Hi
Voltage at node C would be V(V1)+q/C, where
q= charge injected by transistor V2;
C= capacitance at node C;
If transistor is of NMOS type than q would be negative - so resultant voltage would be lower than V(V1).
Reactions: MammPp
    MammPp
Hi MammPq,
I think that: voltage at node C will be a little bit less than VDD due to the charge injection but enough to keep transistor in the right side on (i. e. VGS higher VT)
Reactions: MammPp
    MammPp
Hi all,
Thank you for your answer,
I used HSPICE to simulate this circuit, by consider at V1 and V2 is Vdd.
Let Vdd = 0.9V
The strange result this voltage at node C is equal to 0.13 something, which I concerned that,
From this circuit, if V1 and V2 is Vdd, the other transistor is on/off ?
Moreover, when V2 is off suddenly, voltage at node C is still there or gone ?
and why ???
Hi MammPq
1) If V1 and V2 is VDD, so both transistors are ON, and node_C is ~ (VDD - VTH_n). Where VTH_n is the threshold voltage of NMOS.
2) If V1 is VDD and V2 is gnd, so, node_C is a little bit less than (VDD - VTH_n) due to the charge loss. Therefore, transistor in the rigth is still on.
You can check this in my simulations using 0.18 um technology and VDD = 1.8.
I hope the explanation is clear now. If you have other concern, you can post it again.
Reactions: MammPp
    MammPp
The figuring of q, is always tricky. Up until the point
that the channel "goes away", the gate charge will
be returned to the (presumably stiff) V1 with the G-S
portion of charge bleeding back at an RC limited rate.
It is not Q=cox*(VH-VL) in the end, because of this.
A charge-conserving model and one well fitted to
(this wafer & lot's) reality is wanted.
Reactions: MammPp
    MammPp
thank you for your answer.
It's clear for me now
