bymin5
- Joined
- Jun 14, 2010
- Messages
- 7
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 1,283
- Location
- South Korea/Canada
- Activity points
- 1,358
When I ran the Conformal, I encounted non-equivalent..
So, I analyzed non-equivalent point using the command "analyze_nonequivalent 12542"
its output is as below,
Analyzing non-equivalent compared points:
(G) + 12542 DFF /I_AR_TOP/I_ce_stop/I_ARFFT/I_fftv2_run_even_top_multi_core_viarom_rtl/run_even_top_viarom_multi_core_inst[1].u_fftv2_run_even_top_viarom_rtl/r22sdf_compuation_block[4].gen_r22sdf_compuation_block.u_fftv2_basic_run_rtl/FIFO_bRAM_eRAM_stg1.u_bf1_fftv2_fifo_rtl/u_fifo_sc/mem_do_n2x_reg_reg[23]
(R) + 7855 DFF /I_AR_TOP/I_ce_stop/I_ARFFT/I_fftv2_run_even_top_multi_core_viarom_rtl/run_even_top_viarom_multi_core_inst[1].u_fftv2_run_even_top_viarom_rtl/r22sdf_compuation_block[4].gen_r22sdf_compuation_block.u_fftv2_basic_run_rtl/FIFO_bRAM_eRAM_stg1.u_bf1_fftv2_fifo_rtl/u_fifo_sc/mem_do_n2x_reg_reg[23]/Q_reg
Compared points' clock are non-equivalent.
Following module is black-boxed in one design, while not in the other:
(G) eclkgen_act_DIVQ115_DIVQ27_DIVQ33_DIVQ43_DIVQ515_DIVQ6127_DIVF0_DIVR0_RANGE4_POL0_BYP682_FBS1_SYNCRESET1_VSEL3 /I_ClkGenPLL/clkwizard_ins/eclkgen_inst
(R) eclkgen_act /I_ClkGenPLL/clkwizard_ins/eclkgen_inst
Compared points' data are non-equivalent.
(G) regfile_w32r32an$i_regfile$OF$rf_w32r32an$layer2$OF$_rfile_an$layer1$OF$eip_n2x_rfile_inst_WIDTHR32_WIDTHW32_MODERx00004153594e43_STALL20047_INIT_ON20047_INIT_MASTER_FILE0_INIT_MASTER_WIDTH0_INIT_MASTER_DEPTH0_INIT_TYPE4736344_INIT_ROM20047_INIT_STARTW0_INIT_STARTB0_COMP_INITFILE_PREFIXx636f6d706f6e656e7446696c65 /I_AR_TOP/I_ce_stop/I_ARFFT/I_fftv2_run_even_top_multi_core_viarom_rtl/run_even_top_viarom_multi_core_inst[1].u_fftv2_run_even_top_viarom_rtl/r22sdf_compuation_block[4].gen_r22sdf_compuation_block.u_fftv2_basic_run_rtl/FIFO_bRAM_eRAM_stg1.u_bf1_fftv2_fifo_rtl/u_fifo_sc/mem0/single_row_blk.row/column_block[0].inst/read_mode.layer1/w32_block.inst_w32r32an_block.layer2/i_regfile
(R) regfile_w32r32an /I_AR_TOP/I_ce_stop/I_ARFFT/I_fftv2_run_even_top_multi_core_viarom_rtl/run_even_top_viarom_multi_core_inst[1].u_fftv2_run_even_top_viarom_rtl/r22sdf_compuation_block[4].gen_r22sdf_compuation_block.u_fftv2_basic_run_rtl/FIFO_bRAM_eRAM_stg1.u_bf1_fftv2_fifo_rtl/u_fifo_sc/mem0/single_row_blk.row/column_block[0].inst/read_mode.layer1/w32_block.inst_w32r32an_block.layer2/i_regfile
Analysis of non-equivalent compared points:
Unbalanced black box. (Occurrence: 4)
In first case, "Compared points' clock are non-equivalent" <-- How I slove this problems?, I checked the clock pin of both of golden and revised. but its clock pin seems correct connection.
plz, give me advices,
Thanks,
Bymin
Thanks,
Bymin
