curious_engineer
Junior Member level 2
I have an oscillator, whose behavior with respect to time I want to observe. For example, I want to be able to see how long it takes before the oscillator starts oscillating at a desired frequency, if there is any overshoot, if the frequency somehow changes over time, etc.
I cannot figure out a way to do this on Cadence. I can add "frequency(VT("/oscillator_output"))" as an output, but that only plots frequency on the y-axis if I parametrically sweep a design variable. Otherwise, in a transient analysis, it simply displays a frequency value on the ADE window.
Thank you.
Thank you.
