sjamil02
Member level 4
- Joined
- Nov 8, 2009
- Messages
- 72
- Helped
- 9
- Reputation
- 18
- Reaction score
- 5
- Trophy points
- 1,288
- Location
- United Kingdom
- Activity points
- 1,961
Hi All,
I am new to digital design. I tried to simulation my VHDL code including the testbench (see below).
library IEEE;
use IEEE.std_logic_1164.all;
entity tb_keypad is
end tb_keypad;
architecture behaviour of tb_keypad is
signal keypad_in : std_logic_vector(6 downto 0);
-- signal dec_in : std_logic_vector(3 downto 0);
signal clk : std_logic :='0';
signal reset_N : std_logic;
signal count : std_logic_vector(2 downto 0);
-- signal count : std_logic;
signal dec_out : std_logic_vector(3 downto 0);
signal accept_out : std_logic;
signal error_out : std_logic;
component keypad
port (keypad_in : in std_logic_vector(6 downto 0);
-- dec_in : in std_logic_vector(3 downto 0);
clk : in std_logic;
reset_N : in std_logic;
count : inout std_logic_vector(2 downto 0);
dec_out : inout std_logic_vector(3 downto 0);
-- count : out std_logic;
accept_out : out std_logic ;
error_out : out std_logic);
end component;
begin
test_unit : keypad
port map (keypad_in => keypad_in,
clk => clk,
count => count,
dec_out => dec_out,
reset_N => reset_N,
accept_out => accept_out,
error_out => error_out);
test_block : block
begin
keypad_in <= "0001010",
"0000010" after 100 ns,
"0000100" after 200 ns,
"0000110" after 300 ns,
"0001000" after 400 ns,
"0001011" after 500 ns,
"1111010" after 600 ns,
"1110010" after 700 ns,
"1110100" after 800 ns,
"1110110" after 900 ns,
"1111001" after 1000 ns,
"1111011" after 1100 ns;
reset_N <= '0', '1' after 50 ns, '0' after 100 ns, '0' after 200 ns;
clk <= not clk after 30 ns;
end block;
end behaviour;
library IEEE;
entity keypad_dec_lb is
end keypad_dec_lb;
architecture decoder_logicblock of keypad_dec_lb is
signal connect : std_logic_vector (3 downto 0);
component keypad_dec_lb is
port (key_pad : in std_logic_vector(6 downto 0);
clk : in std_logic;
logblk_input : in std_logic_vector (3 downto 0);
accept_out : out std_logic;
error_out : out std_logic;
dec_out : out std_logic_vector(0 to 3));
end component keypad_dec_lb;
signal skey_pad : std_logic_vector(6 downto 0);
signal sclk : std_logic;
signal sreset_N : std_logic;
signal slogblk_input : std_logic_vector (3 downto 0);
signal saccept_out : std_logic;
signal serror_out : std_logic;
signal sdec_out : std_logic_vector(0 to 3);
begin
keypad_unit: keypad_dec_lb
port map (key_pad => skey_pad,
clk => sclk,
reset_N => sreset_N,
logblk_input => sdec_out,
accept_out => saccept_out,
error_out => serror_out,
dec_out => connect
end decoder_logicblock;
library IEEE;
entity keypad is
clk : in std_logic;
accept_out : out std_logic := '0';
end keypad;
Architecture rtl_decoder of keypad is
begin
process (clk)
begin
case key_pad is
WHEN "0110111" => dec_out<= "0001";
WHEN "1010111" => dec_out<= "0010";
WHEN "1100111" => dec_out<= "0011";
WHEN "0111011" => dec_out<= "0100";
WHEN "1011011" => dec_out<= "0101";
WHEN "1101011" => dec_out<= "0110";
WHEN "0111101" => dec_out<= "0111";
WHEN "1011101" => dec_out<= "1000";
WHEN "1101101" => dec_out<= "1001";
WHEN "0111110" => dec_out<= "0000";
WHEN "1011110" => dec_out<= "1010";
WHEN "1101110" => dec_out<= "1011";
WHEN OTHERS => dec_out<= "XXXX";
end case;
end process;
end rtl_decoder;
library IEEE;
entity keypad_lb is
clk : in std_logic;
end keypad_lb;
architecture logic_block_rtl of keypad_lb is
signal input : std_logic_vector(3 downto 0);
signal output_1 : std_logic_vector(3 downto 0);
signal output_2 : std_logic_vector(3 downto 0);
signal output_3 : std_logic_vector(3 downto 0);
signal output_4 : std_logic_vector(3 downto 0);
signal output_5 : std_logic_vector(3 downto 0);
signal output_6 : std_logic_vector(3 downto 0);
TYPE byte_cnt IS (cnt1, cnt2, cnt3, cnt4, cnt5, cnt6);
SIGNAL byte_cnt_state : byte_cnt := cnt1;
begin
process (clk, byte_cnt_state)
variable count : integer :=0;
begin
IF (reset_N = '1') THEN
accept_out <= '0';
error_out <= '0';
count := 0;
byte_cnt_state <= cnt1;
ELSE
end if;
case byte_cnt_state is
when cnt1 =>
output_1 <= logblk_input;
if(output_1 = "1010") then
count := count +1;
byte_cnt_state <=cnt2;
else
byte_cnt_state <= cnt2;
end if;
when cnt2 =>
output_2 <= logblk_input;
if(output_2 = "0010") then
count := count +1;
byte_cnt_state <=cnt3;
else
byte_cnt_state <= cnt3;
end if;
when cnt3 =>
output_3 <= logblk_input;
if(output_3 = "0100") then
count := count +1;
else
end if;
when cnt4 =>
output_4 <= logblk_input;
if(output_4 = "0110") then
count := count +1;
byte_cnt_state <=cnt5;
else
byte_cnt_state <= cnt5;
end if;
when cnt5 =>
output_5 <= logblk_input;
if(output_1 = "1000") then
count := count +1;
byte_cnt_state <=cnt6;
else
byte_cnt_state <= cnt6;
end if;
when cnt6 =>
output_6 <= logblk_input;
if(output_1 = "1011") then
count := count +1;
byte_cnt_state <=cnt1;
else
end if;
when others =>
end case;
if (count = 6) then
accept_out <= '1';
error_out <= '0';
else
accept_out <= '0';
error_out <= '1';
end if;
end process;
end logic_block_rtl;
I can compile the file succesfully however it gaves error when I start my simulation.
# ** Error: C:/ModelSim 6.4/VHDL/Keypad/src/KeypadTB.vhd(42): Bad default binding for component instance "test_unit : keypad".
# (Component port "count" is not on the entity.)
# ** Warning: [1] C:/ModelSim 6.4/VHDL/Keypad/src/KeypadTB.vhd(42): (vopt-3473) Component instance "test_unit : keypad" is not bound.
# Optimization failed
# Error loading design
Please help.
cheers
sj
library IEEE;
entity tb_keypad is
end tb_keypad;
component keypad
clk : in std_logic;
end component;
begin
test_unit : keypad
clk => clk,
count => count,
dec_out => dec_out,
reset_N => reset_N,
test_block : block
begin
end block;
end behaviour;
library IEEE;
end keypad_dec_lb;
clk : in std_logic;
begin
clk => sclk,
dec_out => connect
library IEEE;
entity keypad is
clk : in std_logic;
end keypad;
begin
process (clk)
begin
case key_pad is
end case;
end process;
end rtl_decoder;
library IEEE;
entity keypad_lb is
clk : in std_logic;
end keypad_lb;
begin
begin
accept_out <= '0';
error_out <= '0';
count := 0;
ELSE
end if;
when cnt1 =>
count := count +1;
else
end if;
when cnt2 =>
count := count +1;
else
end if;
when cnt3 =>
count := count +1;
else
end if;
when cnt4 =>
count := count +1;
else
end if;
when cnt5 =>
count := count +1;
else
end if;
when cnt6 =>
count := count +1;
else
end if;
when others =>
end case;
if (count = 6) then
accept_out <= '1';
error_out <= '0';
else
accept_out <= '0';
error_out <= '1';
end if;
end process;
Please help.
cheers
sj
