lcd using pointers - help needed
garg29
Advanced Member level 1
lcd using pointers
I am trying to combine some charaters to show on lcd using pointers but it's showing me error...."only lvalues may be assigned to or modified"
unsigned char  buf[6];
lcd_clear();
		lcd_goto(0x80);
		*buf ='1';
		*buf++ ='2';
		*buf++ ='.';
		*buf++ ='4';
		*buf++ ='a';
	lcd_puts(buf);
I know i can do this with other simpler methods but i want to do this by using pointers. Actually I'm trying to learn pointers.
I'm doing it on 16F688 with Hitech Picc compiler.
Re: lcd using pointers
buf is a name of an array that is statically defined in the code.
In other words, it is assigned to the stack, you can't change the value of buf as you doing in the code.
For you code to work correctly as you wrote it here, you have to define buf as a char pointer then allocate the storage for it using malloc function. By this, buf will be allocated in the heap and you will avoid this error.
Amr Ali
    garg29
lcd using pointers
Thanks a lot for replying. I'm just a bit confused.... then how does buf work with sprintf like:
sprintf(buf, "%d", 123);
sorry, if I'm asking something wrong.
And can you, Please, tell me a small example on how to write Malloc for this type of application.
Thanks once again,
regards
It works with sprintf because you copy to the contents of buf not modifying buf itself as your original code was doing.
How to use malloc?
I prefer to refer to opengroup.org when I have questions about functions and their usage"http://www.opengroup.org/onlinepubs/009695399/functions/malloc.html"
You use it like this:
char * buf;
buf = (char*) malloc(required size in bytes);
Amr Ali
    garg29
lcd using pointers
Thanks a lofor your immidiate reply. I tried doing this. First it gave me error malloc function missing Then I added malloc.c file from hitech picc folder to my source file list now it's giving me error :-
Error   [480] ; . function signatures do not match: _malloc (malloc.obj): 0x1079/0x42
Error   [499] ; . undefined symbol:
	_sbrk (malloc.obj)
What to do, sir?
just include stdlib.h to your project do not add any other files.
Amr Ali
You have several errors in your original code.
Buf is an array variable. When using buf without an index, it's equivalent to a constant pointer, that holds the address of
the array, but it can't be changed. You need to use a real pointer variable. Also you must add a string terminator to
print the string.
unsigned char  *pbuf;
  pbuf = buf;
  *pbuf ='1';
  *pbuf++ ='2';
  *pbuf++ ='.';
  *pbuf++ ='4';
  *pbuf++ ='a';
  *pbuf = 0;
    garg29
lcd using pointers
I tried that also...... It's not working.... It's giving
	_malloc
lcd using pointers
You have to link the correct library to your code and make sure that malloc is defined for you platform.
Amr Ali
    garg29
lcd using pointers
amraldo: how should i link it ????
FvM: Thanks. Your method is working but it's missing out the first value...i.e. *pbuf ='1'; on display I'm getting "2.4a" instead of "12.4a"
lcd using pointers
what is your compiler and target chip?
Amr Ali
    garg29
lcd using pointers
Hitech PICC & Chip is PIC16F688
