silicide and N-well contact
moisten
Newbie level 6
n-well contact
Hi, I try to use silicide and N-well to form Schottky diode. While laying out in IBM CMRF8SF, I used three layers: n-well, square stud contact(to connect active area or polysilicon line to metal 1) and metal 1. (Certainly there's a DRC error which needs to be explained to foundry). Will silicide and N-well contact be created in this way? If no, I can use n-well, active region, square stud contact and metal 1 to create the Schottky contact. But How to block the source&drain ion implantation?
Thanks a lot.
silicide block
Just don't put p+ (nor n+) beneath your Schottky contact(s), i.e. active area only, and probably you'll need the SAB layer in order to block the salicide beneath the Schottky contacts. Surely you'll get DRC errors. For the n-well contacts, use standard n+ well taps.
    moisten
nwell contact without implant
Is this ever done before, or is it an experiment?
    moisten
n well contact
if youre a mosis customer you should ask on their user group or email support@mosis.com. either way you'll get an answer from one of their engineers
    moisten
ibm silicide
No, in my design kit, there's no layer which blocks the p+ source/drain implant, only a layer to block the n+ source/drain implant (identifies PFETs, P+ junctions and substrate contact) So I remove the active area beneath Schottky contact.
In addition, I should not block the salicide because silicide is used to form the contact.
Added after 1 minutes:
There are some papers on this. And they have used the Schottky diode in ckt.
Added after 46 seconds:
oermens said:
if youre a mosis customer you should ask on their user group or email support(at)mosis.com. either way you'll get an answer from one of their engineers
Thanks!
taps over nwell
We have submitted the layout, but the foundry does not accept the layout with errors. So the silicide and N-well contact Schottky diode cannot be fabricate in this process.
well contact
Thanks for the feedback, and sorry to hear this!
Didn't you try to get green light / an approval from the fab engineers before?
what is the use of n-well contact
No, this is my first time to use this process.
We are using another process which provides SBD pcell.
schottky diodesubstrate contact
We are using another process which provides SBD pcell.[/quote]
What is this SBD pcell ?
