Type conversion in verilog
Mkanimozhi
Full Member level 4
verilog binary
i m designing one concept in verilog and in that i need to compare the binary value with the integer value , how can i perform it , in verilog there is no type conversion function, how could i perform it,plz anyone clarify my doubt .
Kanimozhi.M
verilog type conversion
In verilog you can compare the integer value with the binary one...
please be more detailed in ur question
type conversion in verilog
hi,
This is my code
input [7:0] t1;
input [2:0] address;
always @(posedge clk or negedge rst or rw)
begin
if(!rst) begin
data_out1=8'b0;
mem_status1='b0;
for (i=0;i<=7;i=i+1)
memory1=8'b0; end
else begin
if(rw=='b1 && t1=='b1 && t1==address ) begin
memory1[address]=data_in;
mem_status1='b1; end
else begin
if(rw=='b0 && t1=='b1 && t1==address)
data_out1=memory1[address]; end end
end
in the above code t1==adddres i need to do the write operation but in tat t1th bit is equal to address say if t1[5]==address(101base2=5 in integer) na, to check this condition,how can i write.plz give me an idia.
kanimozhi.M
type conversion verilog
Here is the sample code i had tried...
hope this will be helpful for u..
module valcompare();
reg [15] a;
integer b;
initial
b = 15;
assign c = (a==b);
endmodule
Added after 11 minutes:
Dear Kanimozhi,
The value if t1 is a single bit,
say if i value is 3 , then ti[3] can be only '1' or '0',
but you are trying to compare a single bit value against a 3 bit value ...
saying tht t1 can be never greater than 1... and you are trying to compare with a 3-bit value, which may not be possible
input [7:0] t1;
begin
if(!rst) begin
data_out1=8'b0;
mem_status1='b0;
memory1=8'b0; end
else begin
else begin
end
    Mkanimozhi
verilog integer to binary
hi,
yes, thanks ya, now i understand my mistake in my program.
Added after 29 minutes:
If i need to compare the t the position value with the address na, how will i do, say if the t th poition value is 5 na we will consider this as integer and address is binary and the crossponding binary value of address is 101base2 how to compare with the position value with the address value.
Kanimozhi.M
binary verilog
may be this will work ?
    if ( t1[address] == 1'b1 )
        if ( rw )  memory1[address] <= data_in;
        else       data_out1  <= memory1[address];
    Mkanimozhi
verilog integer conversion
DEAR Mkanimozhi,
I too accept with j_andr, the solution suggested by him should work. please try, if u could not, let us know...
verilog binary to integer
Hi
kalyansumankv i have worked out it, it's working.thanks for ur help.
