The74namesofgod
Junior Member level 3
please tell me all the ways one could link transformers together and the pros and cons. i want to link 2, 3, 4, and 6, transformers. im am trying to gain amps not volts.
I agree with Audioguru, if this an example, just to understand better, ok. If you you need really this voltage (but I don't see where you can use it) you have to search for a person really expert in high voltages.DONT MAKE THIS CONNECTION BECAUSE THIS VOLTAGE IS VERY DANGEROUS ! IF YOU TOUCH ANY WIRE YOU DIE
