how to get OFFSET voltage of THE OP-AMP
wael_wael
Full Member level 4
how to get the offset voltage for an op amp
i am try to simulate MY OP-AMP but i dont know how to simulate offset voltage, any suggestaion
thanx in advanced
offset and span op amp
u should take the mismatching effect into account.
Adjust the W/L from being matched manually or utilize Monte-Carlo analysis.
    wael_wael
opamp_adv
thanks, but still i need the circuit which be used for measuring the offset, and how to do that.
regads
You can simulate the a Av=+1 feedback config, and input a vcc/2 to +ve input. If your opamp have systemic offset, you will read it on -ve input. For random offset, you better to model it from the principle.
    wael_wael
If the OPAMP has only random offset, you can get it by introducing some mismatch purposely. However,I think the correct modelling is not easy.
thanx in advanced
    wael_wael
the way you can do that is to sweep your differential input from say about -0.5V to +0.5V, your offset should fall within this range. the output (Vout vs Vsweep/in) will look like a step. Vsweep/in @ Vout=0 is your offset voltage Vos. so long as in the graph, the point vin=0 falls in the linear region of the step, you will have reasonable results.
    wael_wael
thanx alot, could u show me the circuit configration which used for this measurment
regds
there's a spice netlist for such a simulation on page 22 here:
h**p://webpages.eng.wayne.edu/cadence/ECE7570/doc/OPAMP_ADV.pdf
    wael_wael
thanx in advanced
Try this:
    wael_wael
hi everybody,
thanx for your help, i would like to till MY OP-AMP for Track and Hold T/H application that deal with small term of capacitance.
any way my T/H work as well but still ineed to increase its SFDR.
this measurment of the OP AMP is so complex for me especially CMRR bcz my OPAMP is fully differential .
still i didnt get the solution as well for my case. if there any datasheet or notes can help pls suggest it to mt
regards
since your opamp is ideal, you will get nothing, in practice, we gorund the inputs of the opamp and check the outpur, I believe it is a good idea to model the disturbing effect via a source
    wael_wael
wire ur opamp as vtg follower connect i/p to ground . the vtg of o/p shuld be zero . but due to offset it will not be zero . this will be of very less measure it with some precesion measuring instrument
regads
you may connect you OPAMP as a voltage follower, then sweep the dc voltage at the postive input stage, and check the difference of output voltage with your input voltage .
the offset will be showed by their difference
