difflvl
I have attached the Altium Designer PCB. I think you need 6.3 and up to open it.
The board is contains a 56k dial up modem chipset. The left part, is the digital part, the right side, is the telephone line side device (analog part).
The board is 4 layers. I have the ground plane seperated into 2 planes, one is for digital and one for analog. I tie the digital and analog together under the analog IC.
I also have digital and analog ground copper pour on the top and bottom. Is this bad or necessary? What is the point of the copper pour anyway, assuming you have inner planes?
Is the spacing between the digital and analog ground planes proper or not large enough?
I got this PCB made, and I seem to be having some problems, so Im thinking maybe I have a problem with the digital/analog grounds and pours. The speaker output sounds distorted and its doesn't seem to be stable.
Do you see anything wrong with it?
