How to halt IC TCA785 when overcurrent in the galvanisation
tinhthanthep
Newbie level 5
tca785
I make a galvanisation machine. I use 3 IC TCA785 to control phase for bridge rectifier 6 thyristors. I want halt the machine when overcurrent. The machine will be reset after turn off and adjust volume back to 0 position. could anyone help me the schematic?
Thanks very much!
tca 785
the best solution is:
use one of Hall effect current sensor "LEM" to measure DC current in isolated.
place a low pass filter (RC) and compare it,then you can disable TCA785 in Inhabit pin or using a Integrator + comparator + Reset Relay to down Control Voltage of TCA785.
i Used this solution in DC motor Control.
    V
tca785 schematic
this is simplest form of my solution.
use must adapt it with your circuit.
tca785+isolated
Here is modified schematic. What do you think about it?
tca785
Thanks very much!
can you send me the chematic diagram for 3 IC TCA785 to control phase for bridge rectifier 6 thyristors.
ic (tca785)
Hi gujs !
Maybe the datasheet of TCA 785 will help you.
  • tca785_1557.pdf
Re: tca785
Thanks very much!
Can any one send me 3 IC TCA 785 ..6 scr control cct or nay type of 3 ph control cct ..
send me to this forum or tnp.de.silva@gmail.com
Thanx
TNP
