10 channel ir remote switch board
setiorion007
Newbie level 5
infrared switching board working
Hi guys
I have made the 10 channel remotecontroled switchboard that was posted in full projects below
i have a problem in compiling the asm code of this circuit
iam getting the following errors when i tried to assemble the asm file in mplab
pic is 16f84
Make: The target "D:\Documents and Settings\Swapna\Desktop\aasdasd\10-RMOTE.o" is out of date.
Executing: "D:\Program Files\Microchip\MPASM Suite\MPAsmWin.exe" /q /p16F84 "10-RMOTE.ASM" /l"10-RMOTE.lst" /e"10-RMOTE.err"
Error[113] D:\DOCUMENTS AND SETTINGS\SWAPNA\DESKTOP\AASDASD\10-RMOTE.ASM 126 : Symbol not previously defined (z)
Error[113] D:\DOCUMENTS AND SETTINGS\SWAPNA\DESKTOP\AASDASD\10-RMOTE.ASM 133 : Symbol not previously defined (c)
Error[113] D:\DOCUMENTS AND SETTINGS\SWAPNA\DESKTOP\AASDASD\10-RMOTE.ASM 137 : Symbol not previously defined (c)
Message[302] D:\DOCUMENTS AND SETTINGS\SWAPNA\DESKTOP\AASDASD\10-RMOTE.ASM 161 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] D:\DOCUMENTS AND SETTINGS\SWAPNA\DESKTOP\AASDASD\10-RMOTE.ASM 163 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] D:\DOCUMENTS AND SETTINGS\SWAPNA\DESKTOP\AASDASD\10-RMOTE.ASM 165 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] D:\DOCUMENTS AND SETTINGS\SWAPNA\DESKTOP\AASDASD\10-RMOTE.ASM 183 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] D:\DOCUMENTS AND SETTINGS\SWAPNA\DESKTOP\AASDASD\10-RMOTE.ASM 185 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] D:\DOCUMENTS AND SETTINGS\SWAPNA\DESKTOP\AASDASD\10-RMOTE.ASM 187 : Register in operand not in bank 0. Ensure that bank bits are correct.
Error[113] D:\DOCUMENTS AND SETTINGS\SWAPNA\DESKTOP\AASDASD\10-RMOTE.ASM 227 : Symbol not previously defined (z)
Error[113] D:\DOCUMENTS AND SETTINGS\SWAPNA\DESKTOP\AASDASD\10-RMOTE.ASM 241 : Symbol not previously defined (z)
Error[113] D:\DOCUMENTS AND SETTINGS\SWAPNA\DESKTOP\AASDASD\10-RMOTE.ASM 252 : Symbol not previously defined (z)
Error[113] D:\DOCUMENTS AND SETTINGS\SWAPNA\DESKTOP\AASDASD\10-RMOTE.ASM 256 : Symbol not previously defined (z)
Error[113] D:\DOCUMENTS AND SETTINGS\SWAPNA\DESKTOP\AASDASD\10-RMOTE.ASM 260 : Symbol not previously defined (z)
Error[113] D:\DOCUMENTS AND SETTINGS\SWAPNA\DESKTOP\AASDASD\10-RMOTE.ASM 264 : Symbol not previously defined (z)
Error[113] D:\DOCUMENTS AND SETTINGS\SWAPNA\DESKTOP\AASDASD\10-RMOTE.ASM 268 : Symbol not previously defined (z)
Error[113] D:\DOCUMENTS AND SETTINGS\SWAPNA\DESKTOP\AASDASD\10-RMOTE.ASM 272 : Symbol not previously defined (z)
Error[113] D:\DOCUMENTS AND SETTINGS\SWAPNA\DESKTOP\AASDASD\10-RMOTE.ASM 276 : Symbol not previously defined (z)
Error[113] D:\DOCUMENTS AND SETTINGS\SWAPNA\DESKTOP\AASDASD\10-RMOTE.ASM 280 : Symbol not previously defined (z)
Error[113] D:\DOCUMENTS AND SETTINGS\SWAPNA\DESKTOP\AASDASD\10-RMOTE.ASM 284 : Symbol not previously defined (z)
Error[113] D:\DOCUMENTS AND SETTINGS\SWAPNA\DESKTOP\AASDASD\10-RMOTE.ASM 288 : Symbol not previously defined (z)
Error[113] D:\DOCUMENTS AND SETTINGS\SWAPNA\DESKTOP\AASDASD\10-RMOTE.ASM 296 : Symbol not previously defined (z)
Error[113] D:\DOCUMENTS AND SETTINGS\SWAPNA\DESKTOP\AASDASD\10-RMOTE.ASM 300 : Symbol not previously defined (z)
Error[113] D:\DOCUMENTS AND SETTINGS\SWAPNA\DESKTOP\AASDASD\10-RMOTE.ASM 304 : Symbol not previously defined (z)
Error[113] D:\DOCUMENTS AND SETTINGS\SWAPNA\DESKTOP\AASDASD\10-RMOTE.ASM 308 : Symbol not previously defined (z)
Error[113] D:\DOCUMENTS AND SETTINGS\SWAPNA\DESKTOP\AASDASD\10-RMOTE.ASM 312 : Symbol not previously defined (z)
Error[113] D:\DOCUMENTS AND SETTINGS\SWAPNA\DESKTOP\AASDASD\10-RMOTE.ASM 316 : Symbol not previously defined (z)
Error[113] D:\DOCUMENTS AND SETTINGS\SWAPNA\DESKTOP\AASDASD\10-RMOTE.ASM 320 : Symbol not previously defined (z)
Error[113] D:\DOCUMENTS AND SETTINGS\SWAPNA\DESKTOP\AASDASD\10-RMOTE.ASM 324 : Symbol not previously defined (z)
Error[113] D:\DOCUMENTS AND SETTINGS\SWAPNA\DESKTOP\AASDASD\10-RMOTE.ASM 328 : Symbol not previously defined (z)
Error[113] D:\DOCUMENTS AND SETTINGS\SWAPNA\DESKTOP\AASDASD\10-RMOTE.ASM 332 : Symbol not previously defined (z)
Halting build on first failure as requested.
BUILD FAILED: Fri Nov 24 23:42:40 2006
well iam not that good in pic programming
so i need help from u guys to correct the error
i would appreciate if u guys could help me
iam attaching the asm file in case if uwant to check code.
10channels ir remote
You don't need to reassembly that code as long as you are not doing any modification. Try to use hex file inside 30626_10_channel_remote_software.zip
error[113] : symbol not previously defined (z)
NEVERMIND I FOUND THE ERROR
NOW EVERYTHING WORKS FINE
for this error replace all lowercase z by upper case Z,same for c then the error clear. but me also that "operand not in bank0 "error come, if u have any idea pls reply...
