u can think of it like the input to the LO pair is DC+RF if RF is zero then input is just DC which would result in LO at the IF output but in case of the double balanced , idealy u get at one end of the differential output LO+ and LO- which eleminates each other giving good isolation , note that all this assuming ideal case but in practise u will get good isolation but not infinteSTOIKOV said:I was thinking on this equation : IF=RF-LO, so if frequency of RF=0, then IF would have the frequency of LO ?? can it be possible in a double-balanced topology ?
