Controlling LED color with microcontrollers????
xischaune
Full Member level 1
Hi...
Has anyone ever controlled the color (NOT BRIGHTNESS) of LEDs with the help of microcontroller
Also is there any LED that can give a complete range of colors from white to black by varrying its input current ????
Thanx
What kind of color? is it RGB led that you're talking about?
i want to say ....if i give it say 1mA current...it gives red light...if say 5mA it gives yellow...if 10mA it gives orange...if 15mA...it gives green...if 20mA...it gives blue...and so on...???
A single colour LED will always give you only this colour and you can vary its intensity by increasing or decreasing its current ..
If you want to generate several colours you need RGB LEDs and using 3-channel PWM controlled by a microcontroller change intensity of each channel ..
Regards,
IanP
Color of one LED may not be controlled but you can use tri color LEDs housed in one package. these type of things are available. try seaching "TriColor LEDs".
    xischaune
This should give you a good start.
You can use a LED driver IC like MAX6965:
h**p://www.maxim-ic.com/quick_view2.cfm/qv_pk/4099
anyway If you have available some PWM outputs IanP solution is the cheapes one...
hope this helps,
//a
