Radek
I'm going to start using CPLDs chips from Xilinx soon (with the XC2C32 and XC9536XL) and was digging for information about them for a while. Finally installed the WebPack software (the Linux version), get comfortable with it (syntesized one design too) but I'm still learning....
I have parraler programmer already and I'm just waiting for chips.
But to my goal - I plan to use CPLD as replacement for my cmos based logic circuits. Mostly for smaller PCB sizes and to simplify tracing as the CPLD's I/O pins can be locked manually.
I'd like to make CPLD interefere with more classical chips (cmos 4xxx series) still but it shouldn't be difficult especially that for I/O there is separate voltage supply.
But I have few question as I might need to buy some extra parts eventually in an advance:
- what is voltage tolerance for supply? The ColdrunnerII's specs say 2V MAX but what about using it with higher V anyway (2.4V for an example)? Will it fry instantaneously? (even at very low clocks?)
- will be V regulator like the 78L02 sufficient to power that CPLD?
(looking at its specs it should)
- Xilinx software allow to set many different timing constrains. As I could understand providing the clock isn't needed for plain asynchronous operation?
- I have universal PCB board with place for PLCC44 socket in it. I plan to make my own developing/experimenting board with CPLD. Any special advices for that?
Regards and thanks,
Radek
Regards and thanks,
Radek
