acidwabbit
Newbie level 6
Hi all
Am a freshie and new to designing and have to design a CMOS inverter from scratch...a full custom design ..cannot use standard cells...in other words i have to design an inverter and some other logic gates and incorporate them together to form a flip flop and in turn an asynchronous counter...a bottom-up design...
My system should work at 300MHz and the only other spec i have is that the rise/fall time should be 2ns.
My inverter as i stated earlier could be driving single or multiple other gates. How do i approach the design for the required W/L ratio??...wat should be my starting point??..i've read a couple of books and i always get stuck at trying to determine the value of the load capacitance for my design...i deduce that if i know that then i could do my design. also is it true that for a symmetric inverter i can assume my 'tphl = tfall/2' and similarly for the low-high transition..
I'd really appreciate any guidance related to this.
-the wabbit
-the wabbit
