strombom
- Joined
- Jun 23, 2003
- Messages
- 37
- Helped
- 2
- Reputation
- 4
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- Stockholm, Sweden
- Activity points
- 355
Hi!
I am using a AT91SAM7S128, i made a small evaluation board:
At first I tried to program the FLASH using SAM-BA with the debug-port. Unfortunately my chip is revision B and SAM-BA is only on revision C.
So I built a JTAG-programmer with the Wiggler-design:
I have made sure all connections are correct. Then I downloaded OCD Commander from macraigor.com . http://www.macraigor.com/ocd_cmd.htm
My problem is, it cannot connect...
How am I supposed to control the JTAGSEL port (pin50) ? When i put it in a high state the clock crystal (18.4320MHz) stops, and it does not resume if i do a reset and keep the JTAGSEL high... The crystal only works when JTAGSEL is low.
Has anyone here used AT91SAM7S128 and can help me getting started?
/Johan
Added after 2 hours 59 minutes:
I got it working. I found an old version of OCD Commander 2.2 that worked better...
/Johan
/Johan
/Johan
