PIC32CZ8110CA90208 I2C Supports Clock stretching or not?
newbie_hs
I am using a PIC32CZ8110CA90208-I8MX-SL3 in my design.I would like to know
whether the I2C present in this Microcontroller supports clock stretching or not.
I checked the datasheet,it is not clear. Contacted Microchip AE team no response.
can someone please help me regarding this information
Solution
what I did:
* opened the datsheet
* searched and went to the I2C section
* started a PDF search on "stretch"
* found it
So the datasheets gives informations about clock stretching.
So it´s on you to define what you are looking for and what your requirements are.
We even don´t know if you want to use the PIC as I2C master or slave....
--> Please read the datasheet thoroughly, then ask a detailed question with reference to the datasheet.
what I did:
* found it
Solution
LaTeX Commands Quick-Menu:
