at high freq, gain of CS Amp
Full Member level 4
in Razavi, this circuit's gain is Av = - gm RD
but why? in my opinion, this amp's gain is Av = - gm ( RD \parallel\ Rds)
why this circuit's gain is Av = -gm RD ??
thanks
Hi.
If you read it more carefully again, the author assumed λ=0. which means gds=0 or rds goes to infinity (chapter 6 -> 6.2 -> 2nd paragraph.)
Regards,
EZT
    020170
ezt said:
Hi.
If you read it more carefully again, the author assumed λ=0. which means rds=0 (chapter 6 -> 6.2 -> 2nd paragraph.)
Regards,
EZT
hi EZT, if λ=0 , rds should be infinite, not 0
    020170
thanks everyone. i got it
Gds = ( lambda*Ids) / (1+ lambda Vds) ,
if lambda = 0 , gds = 0 , so then 1/rds = ∞
infinite means, open circuit. yes, rds can be ignored.
