hudyrock
- Joined
- Sep 20, 2021
- Messages
- 7
- Helped
- 0
- Reputation
- 0
- Reaction score
- 2
- Trophy points
- 3
- Location
- Liberec, Czech Republic
- Activity points
- 46
i have problem with power mosfet mentioned in title. I am using simple schematics:
In test circuit I am using halogen light bulb from car as a load (approx 2.7 A). If i set the IN pin (active in low), output is still without power, and pin IS is HIGH. after witching on the IS pin is always HIGH (output circuit open, short to ground and with load).
thank you in advace for your answer.
