how to set a constant array at address in CCS compiler
muruga86
Member level 3
Chennai, India
ccsc const array
can any one help me to set a constant array at a particular ROM address say 0x1000 in CCS compiler.
const char ccs compiler
i think i can be done just like below
#ORG 0x1000, 0x100F
char const array[20]={"1234567890"};
the important thing is;
you can access the table by x=array[1]; or x=array;
but you cannot use this code; ptr=&array;
in this case, a pointer to the array cannot be constructed.
    muruga86
ccs compiler pointer to constant
thanks for ur advice and had implemented.
i want to get the starting address of the constant array how to do that? with our using pointer to constant which is not allowed in ccs
