RTOS for ZYNQ development boards
engr_joni_ee
Advanced Member level 3
I would like to boot the ZYNQ board with embedded linux. I have seen RTOS and Petalinux examples. Which one is less complex and easy to use ?
RTOS is less complex, but these two OSes are too much different to compare them. If you nedd hard "real-time" Linux is not proper.
Best Regards
Do you mean that Petalinux is not real time ?
Pentalinux is a embedded version of linux that is supposed to be easier to use. It is not a real time operating system (RTOS). You should read the wiki page on RTOS to understand the difference.
