yefj
Hello, This code works in endless loop.I want to send the buffer only once
how to i turn off this trigger after one itteration?
Thanks.
Thanks.
#include "em_device.h"
#include "em_chip.h"
#include "em_cmu.h"
#include "em_gpio.h"
#include "em_usart.h"
#include "em_ldma.h"
#define TX_BUFFER_SIZE 10
#define RX_BUFFER_SIZE TX_BUFFER_SIZE
uint8_t TxBuffer[TX_BUFFER_SIZE] = {0x00, 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08, 0x09};
uint32_t TxBufferIndex = 0;
uint8_t RxBuffer[RX_BUFFER_SIZE] = {0};
uint32_t RxBufferIndex = 0;
* @brief USART1 TX IRQ Handler
void USART1_TX_IRQHandler(void)
// Send and receive incoming data
USART_Tx(USART1, TxBuffer[TxBufferIndex++]);
// Stop sending once we've gone through the whole TxBuffer
if (TxBufferIndex == TX_BUFFER_SIZE)
TxBufferIndex = 0;
* @brief USART1 RX IRQ Handler
void USART1_RX_IRQHandler(void)
RxBuffer[RxBufferIndex++] = USART_Rx(USART1);
// Stop once we've filled up our buffer
if (RxBufferIndex == RX_BUFFER_SIZE)
// Place breakpoint here and observe RxBuffer
// RxBuffer should contain 0xA0, 0xA1, 0xA2, 0xA3, 0xA4, 0xA5, 0xA6, 0xA7, 0xA8, 0xA9
RxBufferIndex = 0;
* @brief Initialize USART1
void initUSART1 (void)
CMU_ClockEnable(cmuClock_GPIO, true);
CMU_ClockEnable(cmuClock_USART1, true);
// Configure GPIO mode
GPIO_PinModeSet(gpioPortC, 8, gpioModePushPull, 0); // US1_CLK is push pull
GPIO_PinModeSet(gpioPortC, 9, gpioModePushPull, 1); // US1_CS is push pull
GPIO_PinModeSet(gpioPortC, 6, gpioModePushPull, 1); // US1_TX (MOSI) is push pull
GPIO_PinModeSet(gpioPortC, 7, gpioModeInput, 1); // US1_RX (MISO) is input
// Start with default config, then modify as necessary
USART_InitSync_TypeDef config = USART_INITSYNC_DEFAULT;
config.master = true; // master mode
config.baudrate = 1000000; // CLK freq is 1 MHz
config.autoCsEnable = true; // CS pin controlled by hardware, not firmware
config.clockMode = usartClockMode0; // clock idle low, sample on rising/first edge
config.msbf = true; // send MSB first
config.enable = usartDisable; // Make sure to keep USART disabled until it's all set up
USART_InitSync(USART1, &config);
// Set USART pin locations
USART1->ROUTELOC0 = (USART_ROUTELOC0_CLKLOC_LOC11) | // US1_CLK on location 11 = PC8 per datasheet section 6.4 = EXP Header pin 8
(USART_ROUTELOC0_CSLOC_LOC11) | // US1_CS on location 11 = PC9 per datasheet section 6.4 = EXP Header pin 10
(USART_ROUTELOC0_TXLOC_LOC11) | // US1_TX (MOSI) on location 11 = PC6 per datasheet section 6.4 = EXP Header pin 4
(USART_ROUTELOC0_RXLOC_LOC11); // US1_RX (MISO) on location 11 = PC7 per datasheet section 6.4 = EXP Header pin 6
// Enable USART pins
USART1->ROUTEPEN = USART_ROUTEPEN_CLKPEN | USART_ROUTEPEN_CSPEN | USART_ROUTEPEN_TXPEN | USART_ROUTEPEN_RXPEN;
// Enabling TX interrupts to transfer whenever
// there is room in the transmit buffer
USART_IntClear(USART1, USART_IF_TXBL);
USART_IntEnable(USART1, USART_IEN_TXBL);
NVIC_ClearPendingIRQ(USART1_TX_IRQn);
NVIC_EnableIRQ(USART1_TX_IRQn);
// Enabling RX interrupts to trigger whenever
// a new packet arrives from the slave
USART_IntClear(USART1, USART_IF_RXDATAV);
USART_IntEnable(USART1, USART_IEN_RXDATAV);
NVIC_ClearPendingIRQ(USART1_RX_IRQn);
NVIC_EnableIRQ(USART1_RX_IRQn);
// Enable USART1
USART_Enable(USART1, usartEnable);
* @brief Main function
int main(void)
// Initialize chip
CHIP_Init();
// Initialize USART1 as SPI master
initUSART1();
// After the USART is initialized transfers will automatically start based off of certain interrupt flag conditions
// A new packet will be sent to the slave whenever the TX Buffer is empty after a previous successful transfer
// and a packet will be sent from the slave back whenever it receives a packet from the master and will be handled
// by the USART_RX_IRQHandler
while(1);
