tortoise
Newbie
Hi, I'd really appreciate some help with understanding the following level converter which is meant to convert the input signal (via C3) into the base of the PNP (Q4) to 3.3V/0V at the collector of Q5. The emitter of the PNP is at 36V and its base is driven with a signal that's meant to vary between 36V and 24V @ 2.5khz but sometimes only dips to 28-30V. My understanding is that the PNP should turn on every time the input dips even 1-2V below the emitter.
I've tried a ltspice simulation and it seems to work as expected but in my prototype Q4 refuses to turn on. The components seem to be ok/undamaged. This is part of a larger circuit and everything else works as expected. Can the base of the PNP ever get pulled low wrt the emitter in this circuit? What else could be wrong here? Thanks.
