Send data using hlk-rm04 module
JESBIN
Newbie level 1
I have a searched a lot to find AT Commands to access a web page using HLK-RM04. I have found some links. but that links shows file not fount. Anyone plz help me to solve this problem. I have successfully completed all the configurations and i'm able to get responses of AT commands from the MODULE. But I'm not able to send data to a remote server or access a web page. PLEASE HELP me... Thank You.
Have you configured your RM04module?
kindly find the attached documents
  • RM04.rar
The attached file is excellent but I have a little problem In the rar file the Serial&TCP_UDP Tool.exe file is not good because if I choose wifi client option I can not set correct IP address because intsead of three caracters I can give only 2 caracters. I would like to ask, that Can you attach a good Serial&TCP_UDP Tool.exe file?
Thank you for your help.
Best regards.
you can use any other software like hercules for that purpose
Thank you for your advice. My problem is solved. I had set my device.
Reactions: sotoaa
    sotoaa
HI kindly update the steps how u solved the problem..
b'coz im having one facing the problem in wifi client to my wifi adsl modem is not working ..
Hello, How do you solve your send data issue? I have exactly the same problem. Thanks in advance.
