zeeshanqam
Junior Member level 3
Dear all,
i want to design Probe-fed Microstrip patch antena with defected ground structure (DGS) in HFSS. But i am facing some problem. I have design probe fed patch antenna as explained in the HFSS tutorial. But there is no such information about the Probe-fed with DGS. WHat should I do. Should I use Lumport if yes then How? I need to know and simulate it as soon as possible. So ur help is required, it will be highly appreciated. Thanks in advance for your support and help. Waitng for the reply.
