Simple RiSC Core with 16 bit instructions
2wice
Junior Member level 1
I have to simulate a RiSC processor in Xilinx. But when I use this code to run a .dat file the output seems wrong . I'd be happy if anyone could point out any mistakes I'm doing in the code.
Code Verilog - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
`define ADD 3'd0
`define ADDI    3'd1
`define NAND    3'd2
`define LUI 3'd3
`define SW  3'd4
`define LW  3'd5
`define BNE 3'd6
`define JALR    3'd7
`define EXTEND  3'd7
`define IOP 15:13   // opcode
`define IRA 12:10   // rA
`define IRB 9:7 // rB
`define IRC 2:0 // rC
`define IIM 6:0 // immediate (7-bit, to be sign-extended)
`define ILI 9:0 // large unsigned immediate (10-bit, to be 0-extended)
`define ISB 6   // immediate's sign bit
`define ZERO        16'd0
`define HALTINSTRUCTION { `EXTEND, 3'd0, 3'd0, 3'd7, 4'd1 }
module RiSC (clk);
    input       clk;
    reg     [15:0]  rf[0:7];
    reg     [15:0]  pc;
    reg     [15:0]  m[0:65535];
    reg     [15:0] m1;
    reg      [2:0] iop,ira,irb,irc;
    reg      [6:0] iim;
    reg      [9:0] ili;
    wire      isb;
    reg      [15:0] imm, imma;
    always @(negedge clk) begin
    rf[0] <= `ZERO;
    end
assign isb = m[pc[6]];
    always @(posedge clk) begin
    m1 = m[pc];
    iop = m[pc[15:13]];
        ira = m[pc[12:10]];
        irb = m[pc[9:7]];
        irc = m[pc[2:0]];
    iim = m[pc[6:0]];
    ili = m[pc[9:0]];
    imm = {ili,5'b0};
    if( iop == ADD) begin
    rf[ira] <= rf[irb] + rf [irc];
    pc <= pc + 1;
    end
    else if (iop == ADDI) begin
    if(!isb) begin
    rf[ira] <= rf[irb] + iim;
    pc <= pc+1;
    end
    else if(isb) begin
    rf[ira] <= rf[irb] - iim;
     pc <= pc+1;
    end
    end
    else if (iop == NAND) begin
    rf[ira] <= ~(rf[irb] && rf[irc]);
    pc <= pc+1;
    end
    else if (iop == LUI) begin
    imm = {ili,5'b0};
    rf[ira] <= imm;
    pc <= pc + 1;
    end
    else if (iop == SW) begin
    if (!isb) begin
    imma <= iim + rf[irb];
    m[imma] <= rf[ira];
    pc <= pc+1;
    end
    else if (isb) begin
    imma <= rf[irb] - {10'b0,iim[5:0]};
    m[imma] <= rf[ira];
    pc <= pc+1;
    end
    end
    else if (iop == LW) begin
    if (!isb) begin
    rf[ira] <=  m[imma] ;
    pc <= pc+1;
    end
    else if (isb) begin
    pc <= pc+1;
    end
    end
    else if (iop == BNE) begin
    if (rf[ira] != rf[irb])
    begin
    if (!isb)
    pc <= pc + 1 + iim;
    else if (isb)
    pc <= pc + 1 + {10'b0,iim[5:0]};
    end
    else
    pc <= pc+1;
    end
    else if (iop == JALR) begin
    pc <= rf [irb];
   ira <= pc + 1;
    end
    else if (iop == `HALTINSTRUCTION) begin
    pc <= 0;
    $stop;
    end
    end
endmodule
Well, I dont know how you compiled this, as the $stop Task is for simulation only, not synthesis.
But have you written a testbench? have you tested the code yourself?
This program is only for simulation. I have a top module for this which feeds the clock signal as well as the memory. After every clock cycle it reads the contents of the register. The problem is I am getting the output but the output isn't the same as the expected output.
third line :NAND is key word,,so you mustn't use
it becomes red word
