Cost of small surface mount electrolytic capacitor?
grizedale
Advanced Member level 3
I am trying to find a price for the following surface mount , 250V, 22uF capacitor in quantity of 5000 pieces.
However, all distributors i search dont sell it in high quantity (250 poeces is the highest i found) , and so i cannot find a 5000 pieces quantity pricing
NACV220M250V12.5X14TR15F
Datasheet:
https://www.niccomp.com/catalog/nacv.pdf
Anyway, do you know if this capacitor is simply not available anywhere in high quantity?
-its got a very small size considering its voltage and Faradic rating (250V, 22uF) so i presume it will be very expensive(?), but since i cannot find a price, i dont know.
Mouser carries a very similar component, Aluminum Electrolytic Capacitors - SMD 250V 22uF 20% Tol 12.5x13.5:
Lelon VEJ-220M2ETR-1313
Pricing:
4000 $0.387
6000 $0.358
Most major distributors carry several similar lines of SMD Electrolytic Capacitors, the item above was the closest match to your specifications.
Also you may want to contact Futurlec for a quote, the carry SMD Electrolytics similar in design, although the website only lists up to 50V rated devices. I have found them to be quite competitive, however they can be slow on delivery.
BigDog
thanks,
the Panasonic EB series one (EB series 22, uf, 250v) is a little too tall for us at 17mm.
We are hoping that we dont find that the low height electrolytics are more expensive, ...the VEJ one kindly supplied above looks cheap.
