[SOLVED] Help needed about IR sensor reciever...
nithin kamath
Junior Member level 1
India
hello all,
I am doing a Visitor counter which uses IR LED & Sensor and a counter IC.... I have bought an IR LED and Sensor which looks like this:
i don't know how to connect that 3 Terminal IR sensor... Can anyone help me about this.... What are those 3 terminals..??? How can i connect it...??
With regards,
Nithin Kamath
Your LED -phototransistor should equally well operate with a "DC" light, or, modulated by pulses with 100 Hz up to 40 kHz for a larger distance if needed.
If you happen to get a device like the phototransistor and not know the connections, use an ohmmeter to see between which pins and with what polarity the device changes its resistance when lit or not lit from the IR LED.
Phototransistors are handled like regular transistors; biasing the base allows for a better sensitivity. You can also combine your IR LED with another photodiode; many are sensitive to IR light, too.
