shaiko
Please review the following code for an asynchronous assert synchronous deassert reset circuit.
"rst_i" is an external signal to the IC and "global_rst_o" is the global reset signal intended for destribution as an asynchronous reset for all the registers in the design.
tell me what you thing about it.
entity rst_generator is
port
clk_i, -- global clock input
rst_i: in std_logic; -- external reset input
global_rst_o: out std_logic -- global reset output
end entity rst_generator;
architecture rtl_rst_generator of rst_generator is
signal reg_rst_inp: std_logic;
begin
process (clk_i,rst_i) is
begin
if rst_i = '1' then
reg_rst_inp <= '1';
global_rst_o <= '1';
elsif rising_edge(clk_i) then
reg_rst_inp <= '0';
global_rst_o <= reg_rst_inp;
end if;
end process;
end architecture rtl_rst_generator;
